96 Tacoma 4x4 key won't turn
Old 09-03-2013, 06:34 PM
dougb61's Avatar
Question 96 Tacoma 4x4 key won't turn
I have a '96 Tacoma and I can't get the key to turn. At first the key was stuck in the ignition but I was finally able to get it out. I sprayed a little WD40 in the key hole and the key goes in and out with a little persuasion but now I can't turn the ignition at all. There is no tension on the steering wheel lock. I'm sure I need a new ignition cylinder but from what I can gather in order to remove the old cylinder the key needs to be in the "accessory" position before the release button can be depressed to slide it out. Any hints or suggestions?
Old 09-03-2013, 06:40 PM
Kiroshu's Avatar
Drill it out
Unless you can convince the key cylinder to turn by slightly more forceful methods...
Old 09-03-2013, 06:45 PM
dougb61's Avatar
I've tried to force it but...
I've tried to force it but it won't budge, I'm afraid to turn too hard because I can feel the key start to bend and I'm afraid it will break off.
Old 09-05-2013, 11:18 AM
raretaco02's Avatar
Have you tried turning your steering wheel both ways while trying
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
Cplmike
07-08-2015 08:47 PM
Nickdigg
07-07-2015 06:04 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 96 Tacoma 4x4 key won't turn
