96 4runner ignition switch
Old 10-19-2011, 11:03 AM
Jay1's Avatar
Some times my 4runner wont let the key turn to the lock/off position. It I unhook the battery negative cable it comes right out. I think it might be the interlock solenoid. Its an auto trans. What do you guys think it is?
Old 10-19-2011, 11:19 AM
mynameistommy510's Avatar
I've had this problem a few times. I'll sometimes try slamming the shift into park or ill shift in to park open the door and rock the car back and forth while trying to turn the key to the lock position. Both methods have worked for me. Eventually it stops having the problem after a week and everything is back to normal.
Anyone know a fix?
Old 10-19-2011, 11:23 AM
Staff
DeathCougar's Avatar
This is a common problem in the ignition switches of 3rd gens. The lock cylinders wear out, and won't turn anymore.
If you need an ignition switch Jacob, I have one. You could pick it up if/when you come look at the rest of the parts you asked about on NWW
Old 10-19-2011, 01:01 PM
Jay1's Avatar
I might have to pick one up. Do you have the door locks to?
Old 10-19-2011, 01:42 PM
Staff
yes I do, Door locks and the back door lock. Matching lock set.
It won't be around for much longer. Come pick this thing clean!
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Johntom240
7
07-13-2015 12:18 AM
msane99
07-11-2015 08:08 PM
crashburnoveride
07-10-2015 06:39 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: 96 4runner ignition switch
