96 4runner 3rz O2 sensor Resistance?!?!
Old 09-16-2008, 04:11 PM
brylew's Avatar
I just threw a p0420 (Catalytic converter efficiency Bank 1) and i wanted to test my O2 sensors. Does anyone have the resistances that Sensor 1 and Sensor 2 should be??
1996 4Runner 4x4 4cylinder (3RZ)
Thanks in advance for the Help!
Old 09-16-2008, 04:12 PM
BajaRunner's Avatar
INSPECTION
1. INSPECT HEATER RESISTANCE OF HEATED OXYGEN
SENSOR
(a) Disconnect the sensor connector.
(b) Using an ohmmeter, measure the resistance between terminals
+B and HT.
Resistance:
at 20°C (68°F) 11 – 16 ohms
at 800°C (1,472°F) 23 – 32 ohms
If the resistance is not as specified, replace the sensor.
Torque: 20 N·m (200 kgf·cm, 14 ft·lbf)
(c) Reconnect the oxygen sensor connector.
Old 09-16-2008, 04:15 PM
jason191918's Avatar
http://www.ncttora.com/fsm/2003/Repa...3/hos/insp.pdf
http://www.ncttora.com/fsm/2003/Repa...e3/cip0136.pdf
this help?
Old 09-16-2008, 04:17 PM
maaaaaaaaaan. he beat me to it.
Welcome to YT!
There, beat him to that.
Old 09-17-2008, 07:56 AM
brylew's Avatar
Same Resistance Sensor 1 and 2??
So what i assume from the replies are the resistances should be the same for both Sensor 1 and Sensor 2, even though they are different part numbers??
Thanks for the references too!!
Old 09-17-2008, 10:59 AM
BigBallsMcFalls's Avatar
if it is a different part number, then the front one is likely an air fuel sensor
not an o2 sensor,
and resistance test is not gonna fully diagnose jack.
however, code 0420 -is- the rear sensor, or bad cats, so the
rear in fact is an O2 sensor and the resistance test applies
Old 09-17-2008, 11:49 AM
mkgarrison5's Avatar
Welcome to YT!
hahaha..... i am with big balls, no use in testing. get the correct code, look it up and replace the part.. sleep well
RyanJ989
11
04-07-2021 09:41 AM
Longbed 90
03-11-2019 12:38 PM
scheuvront1993
09-17-2015 06:17 PM
zz_denis
09-06-2015 03:43 PM
LJR
09-05-2015 06:02 AM
Quick Reply: 96 4runner 3rz O2 sensor Resistance?!?!
