'85 22rec vacuum diagram
Old 08-05-2004, 06:31 PM
yotafreakshow's Avatar
anybody have a vacuum diagram for an 85 22rec? i used the under hood diagram for the egr, ect., but need fuel pressure reg. and a couple of vsv lines figured out. I was tracking down a miss and discovered some "mechanic" confused most of the vacuum system in my 4runner. Running much better, still a slight something going on...
Old 08-05-2004, 07:39 PM
RED 85's Avatar
You know I think I could use that also. So anyone got the diagram?
Old 08-06-2004, 07:03 AM
I just found a Factory Manual on ebay-$70, but I have one for my 89 and it's pretty similar, aside from the efi and front axle. Call me cheap, but all I really need is the vacuum diagram.
Old 07-31-2006, 03:40 PM
jeebus's Avatar
22re 85 efi 4runner vacuum sensor issue
I have an 85efi with power steering which use to have AC, never-more. I ran my vacuum lines according to the Haynes (85 was nice'n simple) but i don't know what to do with the power steering's "idle up valve" which has two extraneous openings (bottom and back).
According to the 84efi diagram they should run to a three-letter-acronym-sensor, of which I have two but don't know which goes where. (one for ac maybee?) One is cyan (light blue) while the other is black, I'm hoping someone else knows which goes to what.
I don't trust the routing's previous state as an indicator because it was pretty far off when i got it, but I can post more pics if that would help...
https://www.yotatech.com/forums/show...4runner+vacuum
Thanks, Jeebus
Diagram Ref: Haynes656 "Toyota Pick-Ups & 4-Runner 79-94" page 174
kawazx636
10-06-2021 03:03 PM
Steven.m.paulk
06-07-2020 10:45 AM
zytra
01-24-2019 03:16 PM
zanzabar0
10-11-2015 02:56 AM
puddlepirate
09-29-2015 08:02 PM
Quick Reply: '85 22rec vacuum diagram
