60 degree vent temp on 2003 tacoma
Old 06-04-2012, 01:21 PM
jdw1's Avatar
Is this normal? Its 95 degrees outside. Even when im on the hwy. my dads blows 40 degrees in his tundra
Old 06-04-2012, 02:31 PM
rworegon's Avatar
This is with the A/C on? If so, you may need a charge.
Old 06-04-2012, 02:37 PM
Lycanistic's Avatar
A/c temp is going to vary with humidity, and also whether it is on max or fresh air. If you choose to do a chill can, try to avoid the ones with leak sealer as they can clog up your system.
Old 06-04-2012, 02:56 PM
jdw1's Avatar
Yes a/c is on. Ive put on recirculate and fresh air but notice no difference.
Old 06-06-2012, 07:47 PM
revenantdead's Avatar
30 degrees below ambient temperature is USUALLY the best performance threshold i ever see and i work at a dealership on low mileage cars. if you're getting 60 on a 95 degree day that's pretty good in my book
Old 06-08-2012, 09:05 PM
98_3RZ's Avatar
in a GOOD working system, vent temp should be 38 to 44 degrees. it sounds like your low on refrigerent, but Lycanistic is right, humidity will affect perfomance, more humidity, means more ice build up on the evaporator. also take into account why you might be low. you might have a small leak, or moisture contamination, or it might be overcharged. if you really want it to work good, take it to a shop so they can pressure test it, and vacuum test it. and go from there.
the1998sr5
15
07-14-2020 08:35 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
dropzone
08-11-2015 05:16 PM
TJWilly
07-31-2015 02:05 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: 60 degree vent temp on 2003 tacoma
