5VZfe and 3VZe valves ?
Old 03-03-2011, 05:25 PM
trx125's Avatar
Are the intake valves on these the same and interchangeble? I know the 5VZ and the 3VZFE are, I am pretty sure they are, but wouild like a second opinion just to confirm this, Thanks!
Old 03-03-2011, 06:39 PM
mt_goat's Avatar
I doubt it since the 5VZFE has 24 valves and the 3VZE has 12.
Old 03-03-2011, 07:53 PM
trx125's Avatar
I will let you know tomorrow. I have a spare 3vz engine, so I'm take the head off and see.
Old 03-04-2011, 05:06 AM
mt_goat's Avatar
I'll bet you a case of bud they aren't.
Old 03-04-2011, 05:09 AM
blake.nemitz's Avatar
the the 3vzFE has the same heads as a 3.4 with a different cam profile and are 24 valve heads, the 3vze on the other hand is a 12 valve motor and will not interchange.
FE means dual overhead cams. all FE yota motors have 4 valves per cylinder
Old 03-05-2011, 09:43 PM
just call me smithy's Avatar
they are not the same. i have done a valve job on both motors and to my surprise the 3vz valves are larger.
Old 03-07-2011, 08:50 AM
hmmm maybe thats why people swap them. 3vzFE heads on the 3.4 due to the flatter torque curve. i for one wish i had the money and time to build a 3.0 3vze with fe heads from 3vzfe and taco intake instead of a 3.4 swap.
Old 03-07-2011, 08:58 AM
mt_goat's Avatar
I think he means the 3VZE valves are larger than the 5VZFE or 3VZFE valves. They are larger because there is only one intake and one exhaust per cylinder. To fit 4 valves/cyl in the small head space they have to be smaller. And since there are twice as many valves they don't need to be as big.
Old 03-07-2011, 09:23 AM
oh i thought he was talking fe heads. that makes sense and i stand by my original statement that 3.4 and 3.0 fe heads are the same with different cam profiles. of course the 12 valve ones would be bigger ha ha
ManzDaKlown24
08-22-2015 10:25 PM
ChiefTetlow
08-10-2015 04:19 AM
snosurfer
08-05-2015 03:55 PM
jon.r
07-11-2015 03:34 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 5VZfe and 3VZe valves ?
