5vz-fe oil and cooling fluid diagram
Old 06-04-2011, 05:01 PM
Ruadd's Avatar
Hey everyone, I am looking for a fluid diagram of the 5vz-fe engine. I have a clogged oil port and could use this diagram to troubleshoot my issue. Any help is greatly appreciated!!
Old 06-05-2011, 06:15 PM
J2F42C's Avatar
Here you are:
Old 06-06-2011, 09:14 AM
Ruadd's Avatar
Oil flow diagram for 5vz-fe High oil pressure at the oil pressure sensor.
My apologies I should have been more specific. I also need an oil flow diagram for the 5vz-fe engine. When I was changing my valve cover gaskets I think a piece of plastic from the injector harness broke and dropped down into my head. I have extremely high oil pressure at the oil pressure sensor. So basically I am trying track down where I have a clog.It's a rebuilt engine with about 30,000 miles on it so I doubt it would have anything to do with a gunned up oil port. However Any advice, diagrams or thoughts is greatly appreciated! Thanks guys
Old 06-06-2011, 10:51 AM
ntoracn's Avatar
The oil pressure regulator is built into the oil pump that's bolted to the front of the front of the motor. Not sure how the plastic could have gotten past the oil pick up screen to get into the regulator, but none the less that's where the pressure is regulated from.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
jasonty
41
12-23-2018 01:00 PM
88yodabasket
07-13-2015 01:32 PM
Rkellerman
07-12-2015 08:42 AM
Quick Reply: 5vz-fe oil and cooling fluid diagram
