5VZ-FE installing oil pressure guage
Old 12-06-2011, 01:10 AM
YodaPala's Avatar
I want to install an aftermarket oil pressure guage in my 4runner, where on the engine can I access an oil pressure reading?
Old 12-06-2011, 05:36 AM
dntsdad's Avatar
The sender for the idiot light is towards the front of the motor on the driver's side, behind the alternator.
To add a gauge, you would have to remove that and lose your idiot light, or get a "Y" adapter to run both.
Old 12-06-2011, 06:09 AM
YodaPala's Avatar
K thx
Old 12-06-2011, 04:22 PM
cpizzle42's Avatar
I believe there is a plugged off port above the stock sending unit. But may be wrong. If not, ditch the stock one, and pull the dummy light bulb out of the dash.
Old 12-06-2011, 04:54 PM
streetlancer's Avatar
Or, you could use one of these:
^ Thats what i used on my MR-S.
Old 12-06-2011, 05:25 PM
dntsdad's Avatar
you shouldn't have to pull the light. I wont come on when you unplug the wire from the sending unit as nothing is being "sent" to turn it off
Old 12-06-2011, 07:52 PM
YodaPala's Avatar
oil guage
Thanks to all for the info, I'll let y'all know how the install goes and ill put some pics up.
Old 12-07-2011, 05:46 AM
Texas_Ace's Avatar
There are a few extra oil ports next to the oil filter. They have lugs int hem from the factory. Just pop them out and put the sensor wherever you want. The ports are 3.8" so you will need an adapter. I have both my oil pressure and oil temp sensor in those ports.
Old 08-12-2014, 04:28 AM
Nvestor88's Avatar
Anyone have pics of an oil pressure gauge install?
Old 08-13-2014, 01:48 PM
wyoming9's Avatar
Red face
Pictures of what??
The fitting in the block??
Or the gauge sitting on the dash??
Old 08-13-2014, 07:29 PM
Nvestor88's Avatar
Fitting on block.
Old 08-14-2014, 05:31 AM
Texas_Ace's Avatar
Originally Posted by Nvestor88
Fitting on block.
No pictures but just get under there and look at the oil filter. There are a few allen bolts below it. Take them out and use an adapter to install the sensor. I have both the pressure and temp installed there.
Old 10-05-2014, 03:30 PM
ThorInc's Avatar
Any chance of a link to the 3/8s adapter that you are referring to?
Old 10-05-2014, 04:37 PM
Texas_Ace's Avatar
I got mine at home depot. Just your basic 3/8 NPT to 1/4 NPT adapter.
I think technically it is a BST (SP?) thread but the NPT works fine with some teflon tape.
Old 10-06-2014, 12:13 AM
wyoming9's Avatar
Red face
I buy the Metric adapter kits from Summit Racing
I am not real sure but I think it is a M10x1 thread off the top of my head.
which the adapter takes to pipe thread that most gauge installation kits thread into
Old 10-06-2014, 02:57 PM
vasinvictor's Avatar
It is a BSPT. You won't have a problem using NPT until something like 25 threads deep. Picture of where one port is:
Old 10-06-2014, 03:44 PM
BigBluePile's Avatar
Yup, that's the port I used. That plug was really in there too, be prepared lol.
Old 10-07-2014, 03:55 AM
Texas_Ace's Avatar
Yep, same thing I did to mine.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 5VZ-FE installing oil pressure guage
