4x4 Automatic transmission mounts
Old 02-11-2008, 08:15 AM
iceman601's Avatar
alright guys, I got a upcoming 4wd conversion project going on for my 97 4runner
I've searched and found a write up from sonoran steel, but that one is for a manual tranny setup.
My question is on the tranmissioin mount, I know the mounts are different but are they spaced out differently on a 2wd and 4wd? Pics would help also.
And the tranny I bought came from a 98 Tacoma V6 4x4.
Thanks
Old 03-03-2008, 07:48 AM
iceman601's Avatar
Well the tranny has been swapped out this weekend and will have to sit till next weekend. It turns out that Sonoran Steel info on the 4wd conversion also applys to automatics.....I was hoping it was different
Now I'll have to grind out the original one and move it on over
Old 03-03-2008, 07:52 AM
BajaRunner's Avatar
Well it looks like you've done the hard part, right?
How difficult was it to remove your transmission? How long did it take?
Im probably going to remove mine soon to replace my rear main seal.
Old 03-03-2008, 08:17 AM
iceman601's Avatar
Since it was a 2wd transmission it was a pretty easy to drop as its about half the weight of the 4wd one. I didn't keep track of time but I would say about an hour and a half.
Now putting up the 4wd A340F is another story...this thing is a beast compared to the A340E. I place that sucker on a piece of cardboard and dragged it under. I then took my time lifting that sucker up with a 2x4 onto 4x4 blocks front and back till I could put my first jack under the oil pan with a second jack holding up the transfer case.
Hardest part would be getting to the two upper bolts off an on as space is limited.
Old 03-03-2008, 09:45 AM
infiltrator's Avatar
I am interested in doing this to my 2nd gen.
I am very surprised It didnt take you too much time. That makes me happy, because I think it is possible.
What did you do about the driveshafts and stuff?
Are you going to get a whole new center console for the extra shifter?
Old 03-03-2008, 09:58 AM
iceman601's Avatar
Driveshafts, center console and shifter were also swapped out to the 4wd one. Had to do some trimming for the transfer case shifter to poke through.
Old 03-03-2008, 10:12 AM
Joe's Toy's Avatar
I'm just interested in how the center console turned out.
Old 03-03-2008, 10:16 AM
iceman601's Avatar
Hahhah....I'll post a few pics later as soon as I get off and clean the camera a bit.....stuck at work when I should be home relocating the crossmember
Here is a pic of the shifter:
Old 03-25-2008, 01:58 PM
iceman601's Avatar
Problem solved with a Budbuilt crossmember...it was just easier for me as I didn't want to grind out the oem one and weld it in again
Old 08-03-2017, 01:31 PM
kawaii005's Avatar
which bud built crossmember did you use? the 86-95 one? thanks
mskalmus
05-28-2017 07:51 AM
BeMiceElf
10-10-2015 09:40 PM
shar
07-09-2015 12:38 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: 4x4 Automatic transmission mounts
