4WD transfer box actuator replace problem 4R 96
Old 08-30-2011, 11:34 PM
khann's Avatar
Hi all,
I bought 4R Limited 96 5VZ-FE. Im unable to set it to 4WD - after pressing the button control start flashes and nothing happend. When I try switches and limitis after post: YOTA 4WD it happens that Actuator in transfer case is faulty (some teths on plastic gear are broken). I found this actuator in shop Toyotaparts : http://www.toyotapart.com/41400-34020.html Will it fit to the transfer box??? or is it different one - i cannot find it in drawings.
Regs mac.
Old 01-10-2012, 05:31 PM
likkleBIT's Avatar
What you need is more like 36410‑35060
Check toyodiy.com and look up your vehicle for the right part. For my truck the transfer box parts diagram is here: http://www.toyodiy.com/parts/p_G_200...MSTQ_3611.html
Old 01-11-2012, 03:02 AM
khann's Avatar
thanks already solved in post: https://www.yotatech.com/forums/f2/4...l#post51849864 -
I had VIN problem - number showed SR5 version while it was LIMITED
GreenLion
06-07-2021 10:49 AM
stagger_lee
03-29-2016 06:27 PM
Valvoman
06-28-2015 02:45 PM
WhoahTakeItEasy
Engine Swaps
06-19-2015 02:59 AM
Quick Reply: 4WD transfer box actuator replace problem 4R 96
