4runner "grey wire mod"
Old 11-04-2009, 02:19 PM
^99runner^'s Avatar
i just tried this mod and am having trouble. can anyone help???
i grounded the blue/red wire going to the black box. i grounded it on the bolt that the black box was secured to. could it be the grounding isnt good enough?
Old 11-04-2009, 03:57 PM
^99runner^'s Avatar
finally found the problem. good ole search button led me to it. for all future references you have to ground the wire coming FROM the white female plug, not going to it.. works like a charm, best free mod
Old 11-04-2009, 04:03 PM
Elton's Avatar
Originally Posted by Elton
yes ground the blue/red wire going to the plug
what i said
Old 11-04-2009, 04:35 PM
michalik_piotr's Avatar
why would you want this?? i never feel like i need to lock the rear in 2wd or 4hi.
Old 11-04-2009, 05:18 PM
  #25
cpizzle42's Avatar
Why wouldnt you want this? Its traction all the time. I have a lunch box locker in my runner and I almost like it more than factory e locker, just cause it's less hassle and less to go wrong.
Old 11-04-2009, 06:33 PM
  #26
^99runner^'s Avatar
what i said
yeah u said going to the plug.. u ground the part coming from the plug to make it work though
Old 11-04-2009, 07:11 PM
  #27
Elton's Avatar
ahh ok
Old 11-04-2009, 09:40 PM
  #28
401toy's Avatar
man wish I had a locker! question for you guy with electric lockers, this may also apply to air lockers as well. when your locker is engaged and locked, can you unlock it at any speed or will this damage drive train and diff components?
Old 10-31-2010, 05:44 PM
  #29
Tehaids's Avatar
Back from the dead, but since its halloween it seems appropriate. I just did this mod and to confirm (or repeat what everyone else has said):
1) Remove the kick panel from the floor and the driver side
2) Locate the black box, mine had ABS written on it. The green box is the 4wd computer, but thats not the one you want.
3) Cut the blue\red wire and ground the end that is coming out of the white plug. I used a bolt that was already being used by a ground by 2 brown wires, its just above the green box.
4) Put everything back together and test it out.
Old 10-31-2010, 06:55 PM
  #30
Elton's Avatar
i also made a basic write up over in Tech Write-Ups
Old 06-24-2011, 06:19 PM
  #31
ronronpatapon's Avatar
Thank you very much!!! Works very nice!!!
free MOD are the best
Old 09-18-2011, 01:46 PM
  #32
Swede's Avatar
Well I finally broke down and decided to do this mod since I had the trim and seats out to hunt down a water leak. So after twisting my 44 year old body into the most unnatural position, lo-and-behold, I already did it!!! I have no idea when I did but sure enough, it works!!! I swear I'm getting that old-timers disease... I can't remember what it's called though...
Old 10-15-2012, 06:15 PM
  #33
kornhuskerwizard's Avatar
so in order to get it to engage over 5mph do you also have to cut another wire other then grounding one? does anyone have problems w abs light on after doing this mod? just curious before i cut wires, this seems like the least expensive coolest mod ever!
Old 10-16-2012, 02:22 PM
  #34
Red3.slow's Avatar
Asked above about disengaging.
My E-locker doesn't seem to like to disengage unless I slow down. Although I have been able to successfully disengage it at some speed.
Old 04-20-2015, 05:13 PM
  #35
jjcrookster's Avatar
can I grey wire mod my 4runner
I have an 04 limited V8 4runner with diff lock. Can I do the grey wire mod, and does it work the same being its a open center diff.
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
steve miller
10-10-2015 01:40 AM
toyota32
07-06-2015 05:42 PM
Quick Reply: 4runner "grey wire mod"
