3rd gen short shifter kits
Old 12-04-2005, 08:19 PM
dexter's Avatar
Whats available out there and which on is the best. anyone with real world experience chime in here. thanks
Old 12-04-2005, 09:35 PM
4Crawler's Avatar
B&M probably has the only manual short shift kit out there, I run one in my '85 4Runner adapated from a Tacoma kit:
It works well, throw is shorter by about 40% or so.
More info.
Otherwise, Marlin Crawler can often modify your existing shifter for shorter throw. Not sure if they have the 3rd gen parts or not.
Old 12-04-2005, 10:12 PM
Bob_98SR5's Avatar
MC does not. at least as of last year they dont
bob
Old 12-05-2005, 07:08 AM
4Crawler's Avatar
bob
OK, well in that case B&M is probably it. They only list it for the Tacoma, 2WD, 4- and 6-cyl trannys. I can make adapters similar to what I did on my W56 to fit most transmissions. All I need is a tracing or dimensions of the shifter base bolt holes to make one. That is the flat aluminum part in the center-right of the image above. The B&M shifter is very nice, solid stainless steel and it is adjustable for shifter position.
Old 12-05-2005, 09:12 AM
dexter's Avatar
someone mentioned to me in town that lc engineering makes one also and same with marlin crawler but i guess not. anyone else??
Old 12-05-2005, 09:14 AM
4Crawler's Avatar
LC just resells the B&M short shift kit.
Old 12-06-2005, 10:12 AM
boraxman's Avatar
I just bought the B&M off Ebay, but Summit Racing also has them.I thought i'd give it a try. Will update once its on.
Part # is 45185, B&M Toyota Tacoma 4X4 95-04 Short Throw Shifter
smthwsn357
05-01-2024 07:28 AM
dumpster84
04-30-2016 06:03 AM
jerusry
10-19-2015 05:28 PM
shisha1999
09-21-2015 08:22 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: 3rd gen short shifter kits
