3rd gen auto for manual swap?
Old 09-04-2003, 09:17 PM
cstary's Avatar
has anyone here completed this? i can get a manual + T-case for less than $500, and would love to have a 5 speed (or is anyone interested in a trade???).
does anyone know whether the drive shafts are the same length? what is needed in addition to the tranny and t-case (i.e. clutch, brackets, etc.)? i've pulled the tranny out of the 3.4 before, so i think i could manage a swap if there aren't too many intricacies or fabrication involved . . . . any help or insight would be appreciated!
creed
Old 09-04-2003, 10:42 PM
L33T35T 4Runner's Avatar
i believe the whole computer controls the auto tranny, so youd need a new computer unit
thats what i think anyway.. as my truck says right on the computer "3vz3 4x2 automatic"
Old 09-04-2003, 10:51 PM
Macgyver's Avatar
Email Eric at eric@nw4runner.com
He's the only one I know who has done the swap on a 3rd gen. 4Runner. Do you have a multimode 4wd transfer case? If could you take some pics of it if you do?
Old 09-05-2003, 04:16 AM
SLC Punk's Avatar
Don't forget to buy the pedals, slave cylinder and tank, ECU out of a 5-speed and new interior trim pieces.
Old 09-05-2003, 08:03 AM
cstary's Avatar
thanks for the info, guys!
i was wondering about the ECU - i was hoping that going from an auto to manual didn't necessitate an ECU swap, because the ECU would still be able to figure out the fuel and timing at a particular gear based on the engine signals, but didn't need to have any input into shifting. now the other way around, maunal to auto, i would think you needed an ECU to have control over shifting. i'll email the guru above and see what they think.
cyclinder, pedal, trim . . . got it - that's what i was looking for!
thanks,
creed
Old 09-05-2003, 08:06 AM
SLC Punk's Avatar
Back when I had a 93 Camry V6, I was thinking of doing an auto to manual swap. There are a few guys on toyota nation that have done this. The car runs fine without changing the ECU, but they always have a check engine light on.
Old 09-05-2003, 08:09 AM
cstary's Avatar
i have the stickshift-style (manual) transfer case that's standard on the SR5, with 4hi and 4lo - is this what you mean?
creed
Old 09-05-2003, 08:39 AM
rimpainter.com's Avatar
Not to shoot down your idea, but this would not be worth it. You would be much better off selling your auto and finding a manual.
The time and money would never be worth it going into this project.
Old 09-05-2003, 09:03 AM
cstary's Avatar
allright - maybe that's what i needed to hear . . . .
creed
Old 03-15-2009, 04:35 PM
raydouble's Avatar
Bump an old, old thread to see if anyone else has carried this out, specifically on a 01 or 02' 4Runner as, they didn't come with a manual. The only way I could justify doing it is buying a whole donor vehicle.
Anyone do this, think about it?
Old 03-15-2009, 06:58 PM
crolison's Avatar
just get everything you need trans/tcase, clutch, master cylinder, pedal assembly.
all you have to do is wire it up so your ecu always thinks your truck is in neutral.
Old 03-15-2009, 07:34 PM
raydouble's Avatar
Thanks for the reply........... any insight into the ECU seeing "neutral" all the time?
Old 04-13-2010, 01:39 PM
sprchrgd98t100's Avatar
bump an old thread
im trying to do the opposite and have a post nobody is responding too :https://www.yotatech.com/forums/f161...8-t100-208985/
ive got a 98 t100 4x4 m/t i want to put an auto in (my tranny is going out, bad) ive found a 97 4runner 4x4 auto donor vehicle im pulling the tranny out of. i pulled the computer out today, part #89661-3D320, will this computer work? what do i need to do to the wiring harness, does the ecu need to be flashed? any help would be greatly appreciated!
patrick
Old 01-02-2015, 05:17 PM
chris_morkal@yahoo.c's Avatar
t100 Hi I have a good at with transfercase and ecm and harness that I'm looking to tr
Hi I have a good at with transfercase and ecm and harness that I'm looking to trade for a Mt transfer case mine is out of a 96 t100 so everything you need if interested please contact me at 916 367 2121 QUOTE=sprchrgd98t100;51419377]bump an old thread
patrick[/QUOTE]
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 3rd gen auto for manual swap?
