3rd gen 4Runner advice
Old 12-28-2008, 02:24 PM
fastkevman's Avatar
I've searched for 2 days and really didn't see much on what I was looking for so please don't flame me!
I just purchased a '97 4Runner SR5 4x4 with 131k miles, excellent body and interior and very strong engine for $5000 ( I just couldn't pass it up).
I am not planning on heavy off-road use as I have a pickup for that, this will mainly be my in-town ride.
My questions are:
What are some of the absolute best, easy, and cheaper mods that you guys have done to enhance your pleasure from one of these?
What should I look out for, be wary of, every vehicle has flaws and/or weak points, whats in store for me?
Thanks in advance and have a great new year!
Old 12-28-2008, 02:29 PM
904_runner's Avatar
3.4L? NICE!!!!!!!!!!!!!!
I don't know much, but give it a tune up, you could also look into the deckplate mod, etc.
They are pretty nice the way they are.
Old 12-28-2008, 02:30 PM
Elton's Avatar
almost 170k miles for me just done the basic tune up's gonna do the t-belt here sometime..... as for mods deckplate mod and isr mod are a good start also go with a true flow filter and if you want a little sound a 18'' magnaflow sounds great
Old 12-28-2008, 02:31 PM
SoCalPaul's Avatar
It depends on your preferences. I did springs, shocks & tires.
Old 12-28-2008, 02:32 PM
fastkevman's Avatar
yah, 3.4, auto, no locker though
Old 12-28-2008, 02:37 PM
Mtn Mike's Avatar
My questions are:
Hmm, how about an audio system?
I'm in the same boat; bought a '00 Runner last summer with 100k miles and in great condition. All of my time and efforts have been spent making it as reliable as possible: full tune up, replaced ALL the fluids, replaced all the belts, new Optima battery, fog/driving lights, balance and alignment...you know, all the boring stuff that everyone should do anyway.
Next on the list is new coil springs, and maybe bipassing the factory tranny cooler with an aftermarket cooler.
Old 12-28-2008, 02:38 PM
904_runner's Avatar
oh well still nice either way. The locker would just make it that much better.
My mom has a 99 limited 3.4 auto. 2wd though
Look into a nice set of tires, or an aftermarket locker if you want it.
Old 12-28-2008, 02:41 PM
Elton's Avatar
a e-locker and a 5spd is a nice combo
Old 12-28-2008, 02:42 PM
fastkevman's Avatar
Do these trannys have overheating issues?
Old 12-28-2008, 02:46 PM
Mtn Mike's Avatar
I have had zero issues. But reading this thread made me a little nervous:
https://www.yotatech.com/forums/f2/b...cooler-126953/
To make a long story short, if you're tranny has a factory cooler that runs threw the radiator, these guys say that system is prone to catastrophic failure. I'm not sure what percentage of them fail, but I was gonna do the mod just because it's cheap and easy.
Old 12-28-2008, 04:08 PM
BigBallsMcFalls's Avatar
the system -is not prone to failure- if you stay on top of radiator fluid changes
and that stuff. or drop off things and smash the front end around
corrosion is what kills them. the system is not inherently bad
Old 12-28-2008, 04:16 PM
Mtn Mike's Avatar
Thanks for the input. That certainly gives me some piece of mind, given that if I did do the bipass, it wouldn't be until the spring or summer.
Old 12-28-2008, 05:17 PM
Gerdo's Avatar
Are the rear coils sagging? My 2000 really sagged big time. The axle was about 1/4" of the jounce bumpers (the big rubber cone inside the rear coils, helps carry overloads). You could replace them with stock coils and keep the stock height.
Old 12-28-2008, 05:18 PM
Mtn Mike's Avatar
Where did you buy the replacement stock coils? Dealer? How much?
Old 12-28-2008, 05:55 PM
pattycakes77's Avatar
i would say the '99+ cupholder console is one of the more useful mods to do. i wouldn't waste your time with the deckplate mod. just do some of the preventative maintenance to keep it in good running order and enjoy it.
Old 12-28-2008, 07:45 PM
caffecapri's Avatar
Agreed..first thing, maintenance to keep it going. Timing belt/tranny flush/belts/fluids/etc...keep it going for many more miles.
Old 12-29-2008, 09:00 AM
cackalak han's Avatar
I had a 98 Limited that had a rear spring recall. It was done for free. You should call up your local dealership to see if yours qualifies (give them your VIN). If so, free sag fix!
If you're going to be going through water, get your rear diff breather mod done. If your antenna's on its way out, get the Tacoma whip mod done. Make sure your front sway bar endlinks are in tact. See how the sway bar bushings are holding up. Check the water pump to see if it's leaking.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 3rd gen 4Runner advice
