32x11.50x15 tires on stock 15x7" rims?
Old 04-26-2004, 10:03 AM
pat317az's Avatar
Does anyone run this combo on their rig? They recommend at least an 8" rim for the tires so I am worried about uneven wear over time. Any recommendations?
Thanks
Old 04-26-2004, 10:10 AM
I have 285/75/16(33x11+-) on a 16x7 rim and is ok so far. I dont know if this helps if it doesnt, hopefully someone else will chime in.
Old 04-26-2004, 10:43 AM
Senior Member
jacksonpt's Avatar
I've got 32/11.5-15s on stock 15x7 alloys. I've run them for about 55k miles with no problems. I run them at about 25PSI on road and 15PSI off.
Old 04-26-2004, 11:06 AM
WSU4runner's Avatar
Yep it'll work. I'm running 32x11.5's on my stock 15x7's. You should have no problems.
Old 04-26-2004, 11:18 AM
jx94148's Avatar
I run that setup also. The salesman just wants to sell you wheels so he can make more $$ from you. You don't need 'em.
Old 04-26-2004, 11:33 AM
Scofco's Avatar
I am running mine at 29psi.
It's only been 2 days, so I can't comment on the wear
Old 04-26-2004, 02:25 PM
95_4X4Runner's Avatar
How much did you pay for the 32" BFG MT's? That's what I want next. I have 15X8 Centerlines, so I know they'll fit alright. Did you have to get the SAW's for the 32's to fit?
Old 04-26-2004, 02:50 PM
Scofco's Avatar
I paid $216CDN ea. on sale from $260CDN ea.
I got the SAW's for when I load the heck out of my truck on out voyages the front won't droop at all. You can crank the stock bars, they will work just fine.
I actually don't have my t-bars cranked right now at all, and my rear end is still saggy, and the 32's fit pretty well. I did have to bend the lower valence a bit at the corner, otherwise they rub on it, and they rub at full turn, but not much.
Old 04-27-2004, 11:49 AM
pat317az's Avatar
Thanks guys, thats exactly what i was looking for!
Old 04-28-2004, 10:32 PM
jx94148's Avatar
I forgot to mention... I drive an 87 truck, I put in a 1.5" body lift and they did rub a tiny bit at full articulation.
Its good to run the narrowest wheel possible because the sidewalls are tucked in further and slightly less likely to snag a rock and die. Every half inch can help.
This is all just my oppinion, not gospel. Others will disagree, especially wheel salesmen.
10.50s=6 or 7 inch wide wheels
11.50s=7 inch
12.50s=8 inch
Old 04-22-2014, 04:27 PM
Codex's Avatar
2000 stock tacoma
I just put 32x11.50 BFG ATs on my 2000 Tacoma TRD. Stock. No mods. No lift. just some RSD Bilstein adjustable shocks set at the stock low height.
They seem to fit great on the stock 15x7 alloys. No rubbing at full lock so far. I head down to Baja in a week. I'll let you know how they do in the dirt.
Old 04-22-2014, 04:40 PM
Fossilized
Staff
dropzone's Avatar
You know this is a 10 year old thread?
Old 04-22-2014, 04:43 PM
Codex's Avatar
Sure. But since it's archived and searchable and was the first thing that came up with a search I did then why not comment to help other people who might still be searching for the same info.
Old 04-22-2014, 04:45 PM
Codex's Avatar
I search old threads for the information I need all the time. I guess I'm not concerned about when the thread began.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
chukarhunt
12-08-2019 11:39 AM
coffey50
07-28-2015 10:55 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: 32x11.50x15 tires on stock 15x7" rims?
