3.4L V6 Engine wiring harness question
So, I pulled my engine, trans, and transfer case.
ready to install my new motor, trans, and transfer case....
the new motor had its wiring harness cut, so.... i need a new one or swap over the one from my old engine.
i'd prefer to just get a new harness, but am having a little bit of an issue finding the right harness. there are so many codes out there... not sure what's what...
here's the code off of my old harness - 82121-3G290B
my 4runner is a 99 that was build in 01/99... it's a 4wd auto... can anyone tell me if any harness between 95-99 3.4L V6 auto 4wd would work?
thanks!
thanks!
82121-3G290B is the code that's on my harness...
can't seem to find anything on ebay. did a search on google and a new one is $400 some dollars.
why are there so many different versions with the same drivetrain setup?
The following users liked this post:
Stanley Russell (02-24-2020)
I replaced my 3.4 with an auto one, and kept my manual harness in the engine bay. It was easy enough. If the plugs are different couldn't you just swap with the parts off the old motor? All my plugs were the same. Oh, don't forget the engine temp sensor for the dash gauge, it's really hard to get in the back of the motor by the fire wall. I had to do it like a blind man.
LCE_Performance
10-01-2015 01:03 PM
ChiefTetlow
08-10-2015 04:19 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
