3.4L swap tachometer Q
Old 08-21-2004, 05:01 AM
MTL_4runner's Avatar
Muskie, link doesn't work so give us your name on webshots so we can look you up in the community section.
I'll post that link after.
Old 08-21-2004, 07:42 AM
lbb-1's Avatar
outstanding
don't forget part #'s for mod.
thanks
Old 08-21-2004, 08:51 AM
Well after a little searching I found it....
http://community.webshots.com/user/muskielunge
Have fun with the pics....
Old 08-21-2004, 11:39 AM
lbb-1's Avatar
can someone explain what we are looking at. is there a write up for this mod.
thanks
Old 08-21-2004, 02:49 PM
  #25
914runner's Avatar
You are looking at the circuit board for the tach.
Old 08-22-2004, 03:23 AM
  #26
This is after you disassemble the gage cluster and pull out the tach.
Soldering a 10k ohm resistor will be cake as far as mods go.
Old 08-22-2004, 08:22 AM
  #27
lbb-1's Avatar
need a after shot
Old 08-22-2004, 08:26 PM
  #28
muskie's Avatar
sorry it took a bit of looking. kinda new to the posting pics thing. the one pic should be an after shot. I put in all the info he gave me with the e-mail and pics. I hope it helps out 91runner with his problem.
one question 91runner, how has your wiring harness experience going with ors? just curious as I will be needing to deal with them soon. did you have to send them anything and what did you end up buying from them?
Old 08-23-2004, 11:52 AM
  #29
TeamShiftPoint's Avatar
914runner...did you get your tach working?
nice to hear that you have completed your 3.4 swap.
Old 08-24-2004, 07:48 PM
  #30
lbb-1's Avatar
Write Up
anyone got the detailed write up?
Old 08-24-2004, 09:48 PM
  #31
914runner's Avatar
No I havent gotten the tach working yet, I havent had time to tear the dash apart.
I did not have to send anything to ORS to get the adapter harness but it took them awhile to finally get all of the parts to put it together, about 3 months if I remember right.
Old 08-25-2004, 01:25 AM
  #32
muskie's Avatar
thanks for the update 914runner. I talked with the guy who sent me the pics of the tach. his is working great and the swap has over 3000 trouble free miles. he said he hasn't fixed the oil sender or gauge yet.
I wonder why it takes them so long to make the adaptor.
Old 08-25-2004, 05:01 AM
  #33
my tach has been working great since the end of last summer when we finished the swap...its also working on the other 2 trucks we swapped.
whats up with the oil sender / gauge stuff? it doesnt work? mine does.
Old 08-25-2004, 11:11 AM
  #34
914runner's Avatar
It took them so long because they had to sorce the parts to make the harness. once they got all of the parts in, it only took them about a week to make the harness. If you got the plugs from a wrecking yard and then sent them to him I bet you would have your harness in 2 weeks or less.
Old 08-25-2004, 11:13 AM
  #35
914runner's Avatar
The 3.4L oil pressure sensor sends a different voltage to the gauge and fries the gauge. To fix this you have to swap in the 3.0L oil pressure sensor before you run the rig. I didnt know about this before I started driving my rig and I fried my gauge.
Old 08-26-2004, 02:36 AM
  #36
muskie's Avatar
okay so I don't mean to be a pain 914runner, but I got a few questions. so did they make the whole engine harness for you plus the adaptor? what did you get for a engine package? I am just kinda worried about getting all the stuff I need. trying to find 1 doner is kinda hard and when I do find them, they are usually part of a dealer only auction. thanks in advance.
Old 08-26-2004, 12:08 PM
  #37
914runner's Avatar
No he did not make the engine harness, he just made the adapter harness to adapt the engine harness to the body harness and the body harness to the ECU.
Old 08-26-2004, 03:18 PM
  #38
SEAN_at_TLT's Avatar
We got our motor from a late model Toyota wrecker in Colorado that Mike @ ORS recommended to us. It is called "Central Foreign Auto Supply" They can source complete units.
Old 08-26-2004, 04:10 PM
  #39
lbb-1's Avatar
is anyone working on a detailed mod write up for tach mod?
Old 08-27-2004, 02:36 AM
  #40
muskie's Avatar
thanks 914runner. I just wasn't sure how it worked with them.
lbb-1 I am not sure what else you need to know for this mod. if you take the cluster out, it should all make perfect sense with the pics. the only other suggestion I can offer is the same one I made at the start. get a line out to CO93runner on 4x4wire. he is more than willing to help out fellow yotas.
Quick Reply: 3.4L swap tachometer Q
