3.4L power upgrades...
Old 01-14-2006, 10:16 AM
midiwall's Avatar
Originally Posted by Weasy2k
did you dyno to see if there was any improvments
Well, kinda'. I organized a "dyno day" around these parts (got us a discount!) and it was during the time I had the SMT and was still N/A. The good thing that came out of it was a dyno sheet that showed a 5hp increase across the board from the deckplate mod. The bummer was that the operator shut me down for being too lean while I was A/Bing the SMT and my spark kicker.
Originally Posted by trd_style
just to let you know, this mod will lose 1-2 mpg.
Yeup... Gotta burn fuel to make power. In my case, I increased fuel flow around 4%, which is about .68mpg against my "normal" of that era of 17mpg.
Old 01-14-2006, 11:18 AM
Weasy2k's Avatar
Originally Posted by Bob_98SR5
johnny,
im talking from experience: yes, i could feel the difference in low end torque loss.
bob
from jsu thte muffler? damn man thats nuts
midiwall
dam that sucks, If i can convince my dad to let me borrow his truck to ttest the unit on it for a before and after that would be sweet as i know i can unleash some power form that 3vz-e
Old 08-27-2022, 11:41 AM
MurKZilla208's Avatar
Yea pritty much intake and exhaust is the only thing you can do as of yet. (headers and cat back will yield something)....hopfully cams will be an option in the near future.
Even getting a piggyback like the smt6 that can control fuel and timing will yield some power increase it depends on the engine but I have seen up to 20hp increase
I plan to try doing this on my dads 93 4runner with the 3vz-e 3.slow
the 3vze is easy bigger injectors upgrade your fuel lines from tank with -6an and cleanable filter on outside of framerail with a banjo bolt adaptor straight to the fuel pressure valve on the rear of the passenger side rail and a egr/pair delete and I’ve honestly gained over 100whp in my 91’ 3vze! I’d say almost as fast as a stock 3.4 which I had in my 96’ Tacoma. But once I put bigger injectors in and bigger wires and k&N intake that 96’ was a force to be reckoned with! I’m bout to start again cause I’m in the way to buy a 99’ 4Runner 3.4l! Next will be a 2jz swapped 91’ short box 2nd single cab pickup with 4link and cage and awd if I can get it out of a newer Toyota!
mussy01
12-13-2016 08:20 PM
ksmudrunner99
08-07-2015 06:46 PM
1996Taco
07-20-2015 12:02 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: 3.4L power upgrades...
