3.4 v6 5VZ-FE Thermostat
Old 02-02-2013, 05:27 AM
AlexJet's Avatar
Does anyone knows what is the Thermostat temperature for the OEM Tacoma 3.4 v6?
I'm trying to adopt an electric fan and need to know what sensor should I get based on thermostat temperature.
Old 02-02-2013, 06:11 AM
98SR54RUNNER's Avatar
Edit: It opens between 176º and 183º F and is fully open at 203ºF.
Old 02-02-2013, 06:29 AM
rworegon's Avatar
^^^^ that's correct for the 180°F thermostat and it's fully open at 203°F.
Old 02-02-2013, 06:55 PM
totally a bro
Staff
vital22re's Avatar
Just make sure your jiggle valve is at the 6 o'clock position when you install it.
Old 02-03-2013, 04:25 AM
AlexJet's Avatar
What temperature is actually written on the thermostat? Is it opening or fully opened temperature?
I found one on the web, but it has 90C stamped on it.
Old 02-03-2013, 05:23 AM
rworegon's Avatar
82°C is stamped on the stock 180°F Kuzeh brand t-stat that came in the engine originally which is part number 90916-03075. 90°C is a 195°F stat and is a non-stock part for this engine.
Per FSM (Factory Service Manual):
"Valve opening temperature: 80-84°C (176-183°F)
Valve lift: At 95°C (203°F): 8 mm (0.31 in) or more
If the valve opening temperature and valve lift are not within specification, replace the thermostat."
White Stripe
10-06-2015 10:47 AM
AlexJet
04-03-2013 07:40 PM
AlexJet
02-08-2013 05:15 AM
AlexJet
01-25-2013 06:05 AM
Corey
02-20-2003 06:49 PM
Quick Reply: 3.4 v6 5VZ-FE Thermostat
