3.4 TRD SC dyno
Old 11-16-2012, 11:29 AM
  #41
kleemann1's Avatar
Originally Posted by Texas_Ace
I had and saw SOOOO many reliability issues with the old stuff it was not funny, and it was always an expensive fix. To each their own. Since they started using modern pumps it has got much better.
The meth injection is a nice bonus, helps keep everything cool as the supercharger likes to get REAL hot. IAT's can easily get well over 200 degrees.
Many people just run a 2.2 pulley though, I did for awhile and it worked fine. Didn't make nearly the same power as with meth injection though.
Ive known Richard at ERL for a long, long time- so I might be biased That said the old mag pump was a slick piece of work- like a Rolex Daytona is a slick watch- but probably works "worse" than a $25 Timex (I mean, heck, you have to WIND a Rolex), if you get my drift
Old 11-19-2012, 07:00 AM
  #42
mt_goat's Avatar
The 2.1" pulley works great at higher elevations
Old 11-19-2012, 07:13 AM
  #43
Greg_Canada's Avatar
Originally Posted by kleemann1
DAMN! Expensive suckers- I paid $125 for mine, delivered.
It sounds like it's the same as my OBD1 cat (200 cell)... you are likely running an OBD1 cat... obd 2 cats are much more money.
Old 11-19-2012, 07:28 AM
  #44
93NMyota's Avatar
x2
Old 11-19-2012, 07:38 AM
  #45
Texas_Ace's Avatar
Odd, around here you can get legal cats installed for around $90 and inspected on the same day.
They are even cheaper online, here is the first listing that came up in my quick search: http://www.ebay.com/itm/Thunderbolt-...082d86&vxp=mtr
$50 for an OBDII cat shipped to your door.
Old 11-19-2012, 07:47 AM
  #46
Agreed, however i'm talking about 100% 304 Stainless steel metal core "spun" cats, not standard cats.
Old 11-19-2012, 07:50 AM
  #47
Texas_Ace's Avatar
I guess I don't see the point in spending more then I have to on an item I don't want anyways. Not like I care how well it works as long as it passes the tailpipe sniffer which they have on all the cars I have used them on with flying colors.
Old 11-19-2012, 09:55 AM
  #48
Based on the OP's dyno's, the CAT alone is a 10hp / 12 lb-ft increase throughout the ENTIRE powerband... it's basically like running a LEGAL test pipe.
Old 11-19-2012, 10:02 AM
  #49
Texas_Ace's Avatar
Performance wise the cheaper ones usually work better due to having less material in them to restrict flow. They just wear out quicker and don't clean as well in my experience.
Either way, to each their own, I prefer having no cat personally.
Steven.m.paulk
06-07-2020 10:45 AM
White Stripe
10-06-2015 10:47 AM
LCE_Performance
10-01-2015 01:03 PM
4runnerFireman
09-29-2015 06:24 AM
83
09-27-2015 04:13 PM
Quick Reply: 3.4 TRD SC dyno
