3.4 timing belt visual condition
Old 11-16-2012, 04:04 AM
kornhuskerwizard's Avatar
Hey guys, i took the inspection cover off the 97 last night to look at the condition of the belt. wasnt to impressed so i thought id get some opinions. 165k on the runner and didnt have any previous maintenance records.[IMG][/IMG]
[IMG][/IMG]
Old 11-16-2012, 04:09 AM
bansheeboy2x's Avatar
Mine has looked like that for the last 10k but its not my daily driver either.
Old 11-16-2012, 04:54 AM
waskillywabbit's Avatar
Replace it. Move on.
:wabbit2:
Old 11-16-2012, 05:02 AM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
if i saw that, i wouldn't put a lot of faith in the belt holding on to get me to my destinations... a new belt will be night and day in appearance. for me it's all about reliability (or the belief it's going to get me places). If i can't trust it, i ain't drivin' it
Old 11-16-2012, 05:14 AM
rworegon's Avatar
Replace it with a timing belt kit from AirCabinMan on eBay (excellent price, Toyota OEM parts) and you'll be good for another 90k miles.
Old 11-16-2012, 10:16 AM
So Many Roads's Avatar
At best it was replaced at 90 or 100K miles, if so it's almost ready for a new belt. Worst case that belt is original. Either way, it's ready to be replaced. It's a non-interference motor, so no damage if it does break on you, but you will be stranded...
Old 11-16-2012, 01:23 PM
thanks for the input! never done one before on a 3.4, should i replace the water pump as well?? since im in there and everything?? book time shows 3.2hrs on the belt. hopefully i dont need any special tools, ill do some more research.
THANKS AGAIN!!
LONG LIVE YOTATECH!!
Old 11-16-2012, 02:12 PM
rworegon's Avatar
Yes, on the water pump........well, just.....
Buy this:
http://www.ebay.com/itm/Toyota-TIMIN...4a37e8&vxp=mtr
or this (less Toyota boxes/bags, but OEM brands as above):
http://www.ebay.com/itm/Toyota-3-4L-...f69ef0&vxp=mtr
and buy a crank bolt from your local Toyota dealer ($10 or so) and a gallon of Toyota Red coolant...
make up this nifty crank/cam holding SST:
https://www.yotatech.com/forums/f116...l-tool-186081/
and then.......
Follow this excellent write-up:
http://home.centurytel.net/stevenjac...lt/timing.html
Be sure to torque the crank bolt to 217 ft-lbs!
Old 11-16-2012, 05:39 PM
excellent!! been workn on the 89runner build too tonight, thanks so much for the advice.
Old 11-18-2012, 06:45 AM
Buy this:
and then.......
excellent info RWOREGON!! very detailed write up w great pics!! Im pretty sure i can handle the job, i will get my parts from aircabinman looks like about $355. Ill fab up some of the cam tools and have to come up with a tourque wrench that big, mine is a snap on 3/8 drive (not big enough). Holy cow! 217 ft lbs!
Thanks again!!
Old 11-18-2012, 07:54 AM
rworegon's Avatar
Welcome!
Yes, 217 ft-lbs on a NEW crank bolt. Nothing less!
Keep posting to this thread if your have any issues. 'scribed.
Old 11-20-2012, 01:21 PM
thanks, ill make sure and get a new crank bolt as well.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Cplmike
07-08-2015 08:47 PM
skoti89
07-06-2015 07:45 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 3.4 timing belt visual condition
