3.4 Starters AT/ Manual Difference???
Old 01-05-2013, 06:26 AM
wyoming9's Avatar
Red face 3.4 Starters AT/ Manual Difference???
Now I need a starter to rebuild so I can just put the rebuilt one in and then rebuild the bad one as a spare.
just in and out or else it will end up setting who knows how long.
Is there any difference between the starters although they have two different part numbers between the AT and manual other then maybe the output?
Thanks
Old 01-05-2013, 07:41 AM
2toys's Avatar
as far as i can tell there is no physical difference maybe they ran a different plug. i ran into that when i tried to run a starter from a different year on one of my 3.0s starter was from an AT went into a MT I just snaged the AT plug an repinned it
Old 01-05-2013, 08:29 AM
MudHippy's Avatar
The difference is in power output(of the motor).
Originally Posted by MudHippy
There are actually 4 kinds of OEM starters available for 79-95 Trucks and 4Runners. 3 for 4cyl/V6, and 1 for diesels.
1.0kW = USA manual transmission
1.4kW = USA automatic transmission, USA manual transmission Cold Spec, Canada manual transmission
1.6kW = USA automatic transmission Cold Spec, Canada automatic transmission
2.5kW = diesel engine
AFAIK, the same theory applies to later models(96+). Only the numbers change. So...
1.4kW = USA manual transmission
1.8kW = USA automatic transmission, USA manual transmission Cold Spec, Canada manual transmission
2.0kW = USA automatic transmission Cold Spec, Canada automatic transmission
2.2kW = diesel engine
Old 01-05-2013, 09:17 AM
wyoming9's Avatar
thank you very much I sort of figured that might be the case
I knew it was with the older mid eighties 22REc engines.
But sometimes things change.
Old 01-06-2013, 04:23 PM
danthemanx07's Avatar
I can attest to the fact that there is no physical difference. I didnt change my starter when I swapped in a manual transmission. Tho original starter worked just fine.
Old 01-08-2013, 03:50 AM
hrt4me's Avatar
thanks!
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
ZONAYODA
07-13-2015 07:17 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 3.4 Starters AT/ Manual Difference???
