2001 4Runner sputters between 50 - 60 mph
Old 12-18-2011, 08:23 AM
MOCity's Avatar
My 2001 4Runner sputters at 50 - 60 mph if I accelerate at a normal rate. If I reduce my rate of acceleration I can get by with no sputtering. My CEL is on and Autozone reader gave some type of emissions code. Initially, I was thinking the fuel filter may need replacing (it's never been) but now that I saw the emissions code I was thinking it may need a new catalytic converter. I've got 164K miles on it. Any guidance would be greatly appreciated. I looked under the truck yesterday and saw there are 2 converters. One looked easy to get to; the other not so much. If cat converter is the cause, any particular brand that I should go with?
Old 01-25-2023, 12:38 AM
RunnerYota01's Avatar
I realize your post if from over 11 years ago but was wondering if you able to resolve your issue. I have an 01 4runner that recently started to do the same thing. Thanks, Kevin
Old 01-26-2023, 05:19 AM
Jomoka's Avatar
Get the actual OBDII code and go from there. And be aware that the code is often related to the item that is reporting the issue, but it may not be the cause of the issue. I.e. catalytic converter codes can be related to the MAF, leaks in the intake, bad injectors, etc.
rock99
10-07-2014 07:55 AM
rowdy235
07-03-2009 04:43 PM
fullmann
04-15-2007 08:42 AM
Bratik
12-13-2004 08:52 AM
MonkeyElvis
05-27-2003 05:52 PM
Quick Reply: 2001 4Runner sputters between 50 - 60 mph
