2001 4runner Keyless Remote Programming
Old 05-04-2003, 05:08 PM
Andrey's Avatar
Does anyone know how to program a keyless entry remote for 2001 4Runner SR5? Is there a write up somewhere on how to do this?
Thanks,
-- Andrey
Old 05-04-2003, 05:23 PM
RobT2k's Avatar
Try this it worked for me:
99 Toyota Factory Alarm Repair Manual
Start registration of recognition„h code
The vehicle should be in the following conditions„h
1. The key is not inserted in the ignition key cylinder.
2. Drivers door is open (other doors are closed)
3. Drivers door is unlocked
Insert the key into the ignition„h key cylinder, then pull it out
Within 40 secs.
Press the door lock„h control switch (for manual operation) 5 times to LOCK/UNLOCK at approx. 1sec. Interval
1. Lock ¡V unlock
2. Lock ¡V unlock
3. Lock ¡V unlock
4. Lock ¡V unlock
5. Lock ¡V unlock
Close the drivers door, then open it.„h
„h Again press the door lock control switch (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. Interval
1. Lock ¡V unlock
2. Lock ¡V unlock
3. Lock ¡V unlock
4. Lock ¡V unlock
Insert the key into the„h ignition key cylinder.
Turn the ignition switch from on to lock at approx.„h 1 sec. interval 1 to 5 times to select the mode.
Add Mode
ON ¡V LOCK„h change occurs 1 times
Confirmation mode
ON ¡V LOCK change occurs 3„h times
Rewrite mode
ON ¡V LOCK change occurs 2 times„h
Prohibition mode
ON ¡V LOCK change occurs 5 times„h
Pull out„h the key plate from the ignition key cylinder
When add mode or rewrite mode„h is selected.
Body ECU automatically performs the LOCK-UNLOCK operation once or twice at 1 sec. interval to inform the operator that either the add mode or rewrite mode has been selected
LOCK-UNLOCK occurs once indicates that add mode has been selected
LOCK-UNLOCK occurs twice indicates that rewrite mode has been selected
Press the lock and unlock switches on the transmitter„h switch simultaneously for less then 1.5 sec.
Again press either of switches„h on the transmitter switch for more than 1 sec.
Body ECU automatically performs LOCK-UNLOCK operation once or twice at a 1 sec interval to inform the operator that it has received the signal from the transmitter
LOCK-UNLOCK occurs once ¡V registration of recognition code is completed
LOCK-UNLOCK occurs twice ¡V registration of recognition code has not been completed.
„h Recognition code received first time and second time did not match.
If they are not performed, the mode returns to the normal mode, then start with ¡§start registration of recognition code¡¨.
Proceed to finish registration
If even one of the following conditions is satisfied, registration of recognition codes in completed.
40 secs. Elapses since the„h body ECU response
the driver¡¦s door is closed„h
the key plate is„h inserted in the ignition key cylinder.
4 types recognition codes are„h registered at one time.
Registration of recognition codes(add mode or rewrite mode) is completed.
Old 05-04-2003, 05:27 PM
RobT2k's Avatar
sorry I don't know why but it is supposed to be:
lock - unlock
not
lock iV unlock
Old 05-05-2003, 02:03 PM
Andrey's Avatar
Thank you, thank you! These instructions worked perfectly and now my second remote is functioning just as it was before!
-- Andrey
Old 05-05-2003, 08:23 PM
derrick92130's Avatar
Great writeup. Does anyone have the instructions for turning off the horn beep acknowledgement of locking the doors with the remote?
Old 05-06-2003, 02:54 AM
It'snotmine's Avatar
I don't know how to stop the beeps, but here is a text file of the same instructions if that's easier for anyone. They worked great for me.
Old 04-29-2008, 02:47 PM
natloc's Avatar
Keyless programming
Are these the correct instructions for a 2001 4Runnner factory installed entry system?
Thanks.
Old 04-29-2008, 02:52 PM
scuba's Avatar
from what i understand he had to reprogram his second factory remote as if the battery died and he replaced it
so i would say yes natloc
Old 10-16-2008, 08:41 AM
split67's Avatar
Exclamation Replacing the battery?
Does anyone know how to open the remote on a 99 runner keyless remote system? I just need to replace the battery...
Old 11-22-2008, 02:37 PM
blakeo1991's Avatar
Within 40 secs.
1. Lock ¡V unlock
2. Lock ¡V unlock
3. Lock ¡V unlock
4. Lock ¡V unlock
5. Lock ¡V unlock
1. Lock ¡V unlock
2. Lock ¡V unlock
3. Lock ¡V unlock
4. Lock ¡V unlock
Add Mode
Confirmation mode
Rewrite mode
Prohibition mode
ok i did all of this but after locking and unlocking the doors for the second time im not sure what to do, after i do all this i'm confused then i tried to test it and when i press the lock button the headlights come on, what do i do, oh yeah 2000 toyota tacoma
Old 03-27-2009, 05:29 PM
DeMented Toys's Avatar
Just pry it open with a flat screwdriver...
Old 04-07-2009, 04:07 PM
pendrag's Avatar
I just got a remote with no battery inside. Luckily I already had one so I could determine what size battery to buy. It takes a CR2016 if anyone needed to know that.
Old 07-13-2009, 05:50 PM
BigWavePaul's Avatar
Question Huh
Yep, this is not in plain English. Where does the remote come in? How do you program it to unlock the doors and roll down the window in the back? Registration, confirmation...? Anyone speak 'Toyota Mechanic' so that I don't have to pay one to make my remote work? I was only able to make the doors lock and unlock by themselves after locking them and unlocking them 5 times and turning on and off the ignition 5 times...what's next?
Edit: My battery was dead. So yeah, that could've been it, the reason why it wouldn't program. Once it confirmed by locking and unlocking on it's own, I was set.
Old 08-05-2013, 10:55 AM
poatalbud12's Avatar
Cannot get the system to lock & unlock itself to show It is ready for remote entry
Hey everyone, I'm new here, it looked like the best place to come for help. I cannot get the system to lock & unlock itself to show It is ready for remote entry. I've tried about 3 different sets of instruction for programing the remote.
It just stopped working one day after 6 years with no problems. I've been trying to re-program the remote for about 3 months & no luck. Then one day my daughter asks to use the 4Runner and it works. It worked for one week, then stopped again. any ideas?
Old 11-18-2013, 03:28 AM
Celina Wakley's Avatar
Keyless programming
Hi OP.
Check 4 runner Keyless programming instruction on key fob site:
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
mengquis
07-13-2015 10:39 AM
Quick Reply: 2001 4runner Keyless Remote Programming
