2000 4runner - camshaft position sensor resistance?
When checking the resistance on this sensor, would a reading of 1.104 indicate a faulty sensor, or is my meter display simply showing me 1104? I adjust the fluke to show me a reading in k ohms, and it reads 1.104. The FSM says it should read between 835 - 1400 k ohms, cold. This engine is cold, havent started it for days. Meter says 1.104 - is that a bad sensor?
how often do these actually go bad and how often do they cause misfires? ( I recently replaced the TB/WP and reverified the timing marks line up, on every second rotation of the crank pully.)
P0300
P0302
P0303
OK, thanks for clarifying the resistance values. As fancy as my fluke meter is, it doesnt seem to have a way of rolling that decimal out to the thousandth position.
P0302
P0303
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
