2.7 Idle Surge
Old 07-20-2010, 05:32 PM
NwRunner's Avatar
2.7 Idle Surge
Since i bought my 3RZ Tacoma about 25k miles ago it has always had a couple intermittent problems, and now its surging/rough idle is getting more constant.
The problem only occurs after i have been driving (usually on the highway) and i take out the clutch to coast, my idle will dip down to ~400 then up to ~1000 and do this a number of times until i rev the engine then it idles normally. It has recently started doing this more often and actually killed my truck when i stopped while exiting off the highway. I believe if I can find the source of this problem I will be able to find the rough idle as well.
A separate but possibly related problem is occasional power loss up hills, it becomes gutless with any incline at highway speeds. Again this is intermittent and sometimes can go up the same hills with no problems.
Any ideas?
Old 07-21-2010, 07:01 PM
NwRunner's Avatar
No ideas? it died again today on my way home from work
Old 07-21-2010, 07:34 PM
PismoJoe's Avatar
AIC or TPS would be a good place to start. Fuel filter been replaced at all?
Any CEL codes?
Old 07-21-2010, 07:58 PM
NwRunner's Avatar
I just rebuilt the top part of the motor and physically inspected the IAC and ohm'd the TPS and they both looked good. I replaced the fuel filter about 5k miles ago as well.
Old 07-21-2010, 08:50 PM
PismoJoe's Avatar
My bet is IAC, even if it still looks pretty cute
smthwsn357
05-01-2024 07:28 AM
wafoogalla
11-02-2016 11:02 AM
digdug40
08-28-2015 02:24 PM
accuracy
08-04-2015 08:05 PM
bighaydn
08-04-2015 07:17 PM
Quick Reply: 2.7 Idle Surge
