1st gen gears
Old 09-14-2004, 05:19 AM
JPinNZ's Avatar
Question 1st gen gears
where does every one get their diffs from when they change their tires ie.4.3-5.28? from other toyotas or aftermarket?
Old 09-14-2004, 07:15 AM
seaflea's Avatar
Both! I got mine from aftermarket dealer and had them installed. A friend of mine got a set of used 3rds and we installed them
Welcome to Yotatech
Old 09-14-2004, 07:24 AM
JPinNZ's Avatar
thanks,what trucks/toyotas are u getting lower gears or 3rd members from?
Old 09-14-2004, 07:34 AM
seaflea's Avatar
The gears my friend got were from a guy that had them for sale in the classifieds section. I don't really know what veh. came with certain gears. I'm sure someone else on here can answer that.
Old 09-14-2004, 09:37 PM
superjoe83's Avatar
i would recommend, that if you do get gears, 5.29's are the best for 33's or bigger, and if its a street queen 5.71's for 35's or bigger, a lot of aftermarket companies make different ratios for Toyota diffs, if you have a 84-85 runner you will have a 8" diff in the front and rear, if its a 86-89 you will have a 8" rear and 7.5" front, and if its a v6, you will have a "v6" 8" rear
Old 09-15-2004, 07:54 AM
BLKNBLU's Avatar
Here's a good thread on gear ID in case you're looking at vehicles to swap out of.
http://www.off-road.com/toyota/tech/other/4_axles.html
mskalmus
05-28-2017 07:51 AM
91yotapup
07-27-2015 07:19 AM
noahstancik
07-17-2015 05:38 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: 1st gen gears
