1st Gen 4Run O2 Sensor Problems
Old 06-21-2004, 04:25 AM
colsoncj's Avatar
Ok so I put a new O2 sensor in my truck because the old one was done. I drive the thing for 2 months and now the O2 code is getting thrown by the computer. I checked the signal its putting out and its definately junk. has anyone had this problem before? someone mentioned that the aftermarket O2's (from a parts store) are up to par with a dealer O2. I think I just got a bad one to begin with but who knows... Any comments or suggestions?
Old 06-21-2004, 07:28 AM
Fahrenheit 451's Avatar
Did you get it someplace like Autozone? Perhaps it is still under warranty.
Also, make sure and clear the ECU after changing the o2 so it knows to make the necessary changes.
I recently pulled my o2 and soaked it with throttle body cleaner (since it specifically stated it wouldn't harm o2 sensors), cleared the ECU and put it all back together and was pretty impressed with the change. The truck was running rich and now seems to be running at a much better mix.
The o2 I just cleaned was an Autozone replacement and I haven't had any problems with it so far.
Old 06-21-2004, 08:42 AM
jscarrozzo's Avatar
Get stock Toyota ones....if it is a bosch, thats you're problem..they are junk.
Old 06-21-2004, 02:35 PM
colsoncj's Avatar
Im almost positive its a bosch.... hmmm well thats the second time I've heard that, so I guess its off to buy a new one.
Old 06-22-2004, 11:04 AM
TOR
I can get you one for $93.00, let me know if you are interested.
Old 06-22-2004, 11:26 AM
seaflea's Avatar
I've had nothing but problems with Bosch 02 sensors. I actually still run my original one from 87. It has well over 240,000 miels on it now. The last time I got an 02 code I just pulled it out and cleaned it real good with brake parts cleaner. Havent had a problem since.
Oh yeah, its been at least 6 months since I did that.
some drunk guy
08-03-2021 06:09 PM
sandyota
02-04-2021 11:16 AM
BK2TFUTURE
10-11-2015 08:42 PM
Project90
09-24-2015 11:40 PM
izzmee
08-17-2015 10:20 AM
Quick Reply: 1st Gen 4Run O2 Sensor Problems
