1998 4runner rough idel and surging
Old 10-01-2012, 01:01 PM
Rosa's Avatar
Hey people,have a 1998 4runner limited.It has started to have a really rough
idle and will stall once warm,on the highway you can feel it surging .I have it at my local shop i go to now and have been told that they thought it may be a fuel problem so replaced filter.NOT the problem they say fuel pressure is fine,have been reading up on TPS causing it .
Old 10-01-2012, 02:28 PM
mynameistommy510's Avatar
This could be many variables. Have your spark plugs and wires checked. It also wouldn't hurt to clean the Throttle body, IAC valve, and MAF sensor. Plus maybe run some seafoam
Old 10-17-2012, 10:31 PM
etc.'s Avatar
Check the front O2 sensors to see if they are tight. IIRC, should be a 10mm nut. The wires should be not be burnt.
smthwsn357
05-01-2024 07:28 AM
sandyota
02-04-2021 11:16 AM
icentropy
09-16-2020 02:47 PM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
Quick Reply: 1998 4runner rough idel and surging
