1998 4Runner 3.4L w/TRD Supercharger
Old 08-17-2011, 07:30 PM
  #41
mwc0404's Avatar
ok stupid queston, but how do you add it being a liquid to the intake?
Old 08-17-2011, 07:33 PM
  #42
Texas_Ace's Avatar
You use one of the vacuum ports on the throttle body to suck it in.
I usually put about 1/3 a can in at a time, let it sit for half an hour or so. Then restart it and drive it till it stops smoking (or close to it). Then repeat a few more times till you have as little smoke as possible. More smoke = more stuff being cleaned out. So once the smoke gets lighter means it is getting cleaner.
Old 08-18-2011, 02:34 PM
  #43
mwc0404's Avatar
good ta your online, i need some help bud
Old 08-18-2011, 02:36 PM
  #44
Texas_Ace's Avatar
Sure what do you need?
Old 08-18-2011, 04:34 PM
  #45
mwc0404's Avatar
so after i inject seafoam and let it sit about a half hour should i drive it or should i just crank it and run it up sittin still?
Old 08-18-2011, 05:31 PM
  #46
Texas_Ace's Avatar
Doesn't really matter. Driving it usually makes the smoke go away faster. Just wait till it is mostly gone before doing the treatment again.
Also you can use the throttle to keep the engine running till you get ~1/3 a can in there. If you don't have enough in the engine it won't do much good.
Old 08-18-2011, 05:34 PM
  #47
mwc0404's Avatar
how do you know when its got as clean as its going to get? does it stop smoking for the most part after a treatment when its clean?
Old 08-18-2011, 05:36 PM
  #48
Texas_Ace's Avatar
Basically, It will still smoke some but it will not be near as thick or last near as long. You can tell after you do it a few times that it is done.
I like to drive it around for a day or so after the final treatment to get rid of everything (can take that long) and then change the oil as some seafoam does tend to get in there.
Old 08-18-2011, 05:38 PM
  #49
mwc0404's Avatar
the seafoam bottle also says you can add it to your oil, you think that does any good?
Old 08-18-2011, 05:40 PM
  #50
Texas_Ace's Avatar
I never recommend putting it in the oil, it works great in the gas and intake since there is nothing it can really hurt there but there is a lot it could possibly hurt in the oil so i prefer to not do that.
Old 08-18-2011, 05:42 PM
  #51
mwc0404's Avatar
i hear ya
BeMiceElf
10-10-2015 09:40 PM
taller1
07-16-2015 03:00 PM
mengquis
07-13-2015 10:39 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 1998 4Runner 3.4L w/TRD Supercharger
