1998 4runer ECU location?
Old 01-05-2008, 08:21 PM
superfliez's Avatar
Hi,
I'm a newbie here. Can somebody please let me know excatly where is the ECU for a 1998 4runer LTD 2x4 located? My 4runer has a RS3000 system and I just bought a new aftermarket remote from ebay http://cgi.ebay.com/ebaymotors/ws/eB...SA:MOTORS:1123
according to the discription it should work with RS3000 system, but I'm having trouble locating the ECU, please help..
Thanks
ozziesironmanoffroad's Avatar
under the kick panel on the passenger side.
Old 01-05-2008, 08:25 PM
superfliez's Avatar
Thank you, let me go find it.
Old 01-05-2008, 09:30 PM
toytech76's Avatar
The engine ECU is behind the glove box. Your alarm ecu is under the drivers seat
Old 01-05-2008, 09:31 PM
really? crap... i hate givin wrong info
Old 01-05-2008, 09:32 PM
toytech76's Avatar
lol..no biggie. The engine ecu's for the pre 96 models were in that spot
Old 01-05-2008, 09:41 PM
Staff
DeathCougar's Avatar
Why would you need to get to teh engine ECU? You should only need to get to the alarm control unit.
Old 01-05-2008, 09:57 PM
superfliez's Avatar
Yeah, Thanks alot I found it. It's underneath the carpet under the driver seat.
BTW ozziesironmanoffroad is right the engine ECU is behind the kick panel. Now I now where to find it...
Thank you very much
Old 01-05-2008, 09:58 PM
i was right? holy moley
Old 01-05-2008, 10:26 PM
Staff
uh no. The ECU for all 3rd gen 4Runners is located under the airbag behind the glove box.
1st and seconds have the ECU behind the pass side kick panel.
Old 01-05-2008, 10:28 PM
Staff
The engine ECU is not behind the pass side kick panel. if you found a computer box under there, its definetly not the main ECU. The ECU should have a part number of 89661-XXXXX and will be located under the airbag behind the black plastic upper cover/trim piece of the glove box.
Old 01-06-2008, 07:49 PM
superfliez's Avatar
Yes, my 1998 4runer LTD ECU is located behind the kick panel. The box is a metal case maybe 3x3 big. It says ECU on it with a string of numbers about 11 or 12 digits.
Old 01-06-2008, 08:04 PM
Staff
Then its either been moved, or you do not have a 98 4Runner. Imma go with moved. Every 3rd gen 4runner i have taken apart (about 15) have the ECU under the dash.
Old 01-06-2008, 09:37 PM
toytech76's Avatar
And the ecu isn't 3x3. More closer to 6x6. You probably found a ecu for some other part of the car. Like I said before...pre 96 ecu's were behind the kick panel
Old 01-06-2008, 10:05 PM
Staff
haha get 'im Toytech.
The ECU part number starts with 89661. What is the part number of the one under the kick panel in your 98?
Old 01-06-2008, 10:08 PM
toytech76's Avatar
Old 01-06-2008, 10:10 PM
iceman601's Avatar
Last time I checked, the unit behind the passenger side kick panel is the ABS ECU.
Old 01-07-2008, 04:10 AM
MTL_4runner's Avatar
Yep, it is according to the FSM.
Old 07-19-2008, 04:34 PM
runner 68's Avatar
I'm also looking for the alarm ECU as I need to program an after market remote. I've a 1998 4 runner 2.7L I tried looking for it under the driver seat but no luck. Need help, thanks.
Old 07-19-2008, 04:40 PM
98runner210's Avatar
+1 my '98 Ltd ECU is below the airbag. There is an ABS one in one kick panel and I think a 4x4 one on the other side
DeathCougar
04-01-2018 11:29 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
O Holy P
08-18-2015 02:33 PM
cr@ves4wheelin
3.4 Swaps
08-17-2015 07:47 AM
Athansinis
07-27-2015 08:38 AM
Quick Reply: 1998 4runer ECU location?
