1997 4runner coolant temp sensor
Old 05-22-2010, 10:30 PM
Dare44's Avatar
Anyone know where this is located on a 2.7l on a 1997 4runner I can not find this thing!
Old 05-22-2010, 11:01 PM
NwRunner's Avatar
i do believe its on the left side of the engine where the upper rad hose connects into the block. It should be attached to a coupler at the end of that hose.
Old 05-23-2010, 05:52 AM
Dare44's Avatar
That is the temp sender, the sensor is somewhere else.
Old 05-24-2010, 06:42 PM
Dare44's Avatar
Ok I found it and replace the sensor, it fixed the high idle, hard starting, richness when driving, fuel mileage, overdrive not engaging problem. Figured I would let you know that it is directly underneath the heater core lines that come out of the firewall. Really small hands help alot!
Old 02-06-2015, 06:26 AM
MonkeyJump's Avatar
Engine Coolant Temp Sensor location
Are you able to send me photos of where this thing was located and what had to be done to access it?
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 1997 4runner coolant temp sensor
