1996 tacoma 3.4 superchared questions
Old 11-22-2012, 04:22 PM
slacker's Avatar
I have a BRAND NEW , URD 6 injector "kit" for sale if your interested .
NEVER installed , still in the "bag" , just what you need for this early engine .
PM me if your interested
Old 11-23-2012, 09:21 AM
bigcat84's Avatar
Yea slacker im interested pm sent.
Old 11-23-2012, 03:38 PM
slacker's Avatar
you have a PM
Old 11-24-2012, 11:13 PM
turbo8's Avatar
Slacker, do you have a supercharger for sale too?
Old 11-25-2012, 04:44 PM
  #25
slacker's Avatar
yes .. brand new , but i'm not offering any discounts on it .. full pop retail + shipping costs +++
Old 12-06-2012, 10:12 PM
  #26
bigcat84's Avatar
A friend wants to trade my sc for his stock intake amd cash...what all do i need off his truck to make this work?
Old 12-07-2012, 05:32 AM
  #27
Texas_Ace's Avatar
If you have both trucks in the same place and are friends, get together some weekend and park the trucks side by side. Then remove the parts from one and put them on the other at the same time. This will ensure all the correct parts get where they need to be. Plus things are more fun with friends.
Old 12-07-2012, 05:52 AM
  #28
j2the-e's Avatar
If your truck has the FMU(fuel pressure regulator adapter thing) installed, dont put it on your buddies truck, throw it in the trash. Make sure you use the correct throttle body gaskets for each. The paper one for the charger isn't reuseable. Don't forget about the little one-way valve that goes to the throttle body-it needs to stay on the truck with the charger. Not a bad idea to do an oil change on the charger while its removed.
Old 12-07-2012, 01:35 PM
  #29
bigcat84's Avatar
Ok so all i need to do is my sc off and put his intake inplace of it or what else to do i need off his truck??and what kind or gasket to use for the non sc truck??
Old 12-07-2012, 02:40 PM
  #30
j2the-e's Avatar
The only gasket different from stock is the throttle body gasket. S/C uses a paper gasket with a big round hole and stock uses a metal gasket with a D-shaped hole in it. The intake gaskets are metal and can be cleaned and reused if they are in good shape. If you need to do valve cover gaskets or knock sensors, now would be the time to do those as well. You may have to change various hoses for the breather and such. And there were different throttle cable brackets for the s/c depending on what your truck uses
Old 12-18-2012, 03:27 AM
  #31
bigcat84's Avatar
Can someone post some pics of the stock intake manifold on a 1996 or whatever year has the same intake??i need to see all the hoses and bolt holes and correct belt diagram.this would be a great help.
jgwerth
07-16-2015 03:23 PM
cgilley
07-15-2015 03:32 AM
94whiterunner
07-12-2015 07:15 PM
TokyoD23
07-12-2015 06:01 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 1996 tacoma 3.4 superchared questions
