1996 4Runner wont start - ignition lights on then off
Old 08-12-2013, 07:07 AM
NedRunner's Avatar
About a week ago was the first time I had this problem where the car wouldn't start. I would turn the key and no ignition lights would come on. I put the key in, turn slightly and half the time the dash lights come on, but then cut off as soon as I turn the key enough. I opened the hood to see if I could visibly see something. Nothing. I closed the hood and tried it and the car started and worked fine for about a week up until last night.
Last night I stopped for gas before going home. Get gas and go to leave and it wont start. Tried it about 10 times and then it worked. I got home shut it off and tried to turn it back on and it wouldn't start last night or this morning after repeated tries.
When the lights do not come on on the dash, the door locks or interior lights do not work either. As soon as dash lights work, as does everything else. The battery is only 4 months old. Any suggestions as to what it is? I have never done any starter/alternator work in the time I have owned it. Thanks in advance
Old 08-12-2013, 07:59 AM
meisentones's Avatar
So sometimes you turn the key, and absolutely nothing happens, and sometimes everything works perfect?
I'm going with battery terminals, ignition switch or bad ground. Check your ground cable from negative post on the battery to the engine block. Make sure both connections are tight and secure. Do a search on how to test ignition switch.
Old 08-15-2013, 11:15 AM
the1998sr5's Avatar
Is it making a click noise. My t4r did the same thing for about six months. It turned out to be the starter.
Old 08-15-2013, 11:27 AM
j2the-e's Avatar
This would be my guess
Old 08-16-2013, 02:58 PM
Deverlow's Avatar
3rd'ed on the terminals. I just had to replace my positive terminal while on a road trip 3.5 hours from home. Luckily there was a stealership nearby and it was only a $25 fix. It could maybe be a dead spot in the starter but I'd put my money on terminals not making sufficient connection.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
rbravo1
06-29-2015 01:34 PM
serenity03k64
06-27-2015 07:59 AM
merc1100sc
06-26-2015 05:24 PM
Land yacht
06-28-2002 09:53 AM
Quick Reply: 1996 4Runner wont start - ignition lights on then off
