1996 4Runner ECU - have to reprogram?
Old 01-20-2012, 10:26 AM
cgilley's Avatar
I've been learning a lot about ECUs lately Based on what I read, if you have to replace the ECU, the dealer needs to program it. Most of my reading, the programming involves setting up the immobilizer for the security system. But I admit to ignorance here. I'm just trying to get the damn thing running again.
So, I have a 89661-3D150 ECU. Based on what I read, this is the one for a V6,AT, 4WD SR5. The one that was in my car has had one of its ignition outputs killed. So, it has to go out for repair. Because I was in a hurry, I decided to try and pick up a used one off ebay ($135 risk level, why not?). The engine runs now, but runs very poorly and throws a "cannot sense camshaft position error". This according to the shop (who won't get any more of my business) who gave it a try. Of course, I have no idea if the used unit is bad.
But, I was wondering - is there some special programming for the ecu that needs to be done such that it would work? I've read other people saying that obtained a used ecu - exact part match - and their truck ran fine.
Appreciate your thoughts
Old 01-21-2012, 12:56 AM
wyoming9's Avatar
Red face
I don`t know about the newer ones maybe you are correct!! With a factory Alarm .
I know the older ones you just plugged the correct part # one in and were good to go.
Do you have a good relationship with your local dealer?? Call and ask the Service manager.
Just for my own peace of mind I want to find out be good to know.
Old 01-21-2012, 05:39 AM
wyoming9's Avatar
Red face
Yes any ECU with a alarm unless you get the remotes needs to be reprogramed so the vehicle remotes are able to communicate with it .
Then all works like it should Other wise the vehicle remains disabled.
If this was not the case the whole alarm could be rendered useless just by swapping ecu units
06-01-2021 01:51 PM
BeMiceElf
10-10-2015 09:40 PM
Daneums
08-20-2015 05:36 AM
Sandman
07-14-2015 12:36 PM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: 1996 4Runner ECU - have to reprogram?
