1995 Tacoma EFI Fuse Problem
Old 04-18-2012, 09:29 AM
Whooker23's Avatar
I have 1995 2.7L Tacoma and every once in the while the EFI fuse will blow while I am driving it. I jumped the COR in the diagnosis port and I thought I had it fixed then it blew it again. I replaced the fuse and took the jumper out and it drove for awhile and blew it again. Does anybody have any ideas on what this could be? Suggestions? Thanks.
Old 04-19-2012, 03:08 PM
Whooker23's Avatar
Bump.
Old 04-21-2012, 09:12 PM
Whooker23's Avatar
Help!
Old 04-21-2012, 09:34 PM
tantacoma's Avatar
Originally Posted by Whooker23
Help!
Try replacing the EFI relay. On my 99, the power accessory relay is identical, so it can be used temporarily to troubleshoot.
Old 04-21-2012, 10:34 PM
1994runner's Avatar
check your wiring going to the o2 sensors. sometimes they will rub on the frame or lay on the exhaust causing an intermittent short
Old 04-29-2012, 10:01 AM
Whooker23's Avatar
bump..
Old 04-29-2012, 10:26 AM
rworegon's Avatar
How about telling us what else you've done to track down the problem like checking for bare wires, loose grounds, etc. instead of just bumps and helps?
smthwsn357
05-01-2024 07:28 AM
rushw
07-18-2015 01:46 PM
Sandman
07-14-2015 12:36 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
dpridgeon3
07-09-2015 01:18 PM
Quick Reply: 1995 Tacoma EFI Fuse Problem
