03 tacoma manual hub conversion
Old 05-19-2013, 03:56 PM
Superbacon's Avatar
So I got a 03 tacoma. The front diff went out I bought a 97 tacoma for parts. The 97 has manual locking hubs which I'm putting the diff from it in the 03. I can't use the hubs off the 97 because for one I junked them and for two they were old and ˟˟˟˟ty. I've looked everywhere ad can't find a manual hub conversion kit. I also want the manual hubs because I have a 3 inch skyjacker lift and have gone through too many cv shafts. Does anybody know where I can get a conversion kit or wat all do I need to do it?
Old 05-26-2013, 10:34 PM
wyoming9's Avatar
Red face
Get Hubs for the 97 front end should not be that hard
Now I know most don`t like warn Hubs but the part # is 60459
Now if you also tossed all the other parts you will need 4 nuts 2 locks and 2 thrust washers
You might also need the 2 snap rings and 2 bolts that go in the axle
not sure just how much you threw away.
The hardware can be ordered from your Local dealer
also good to have the correct socket. .
Did you trash the bearings as well??
BeMiceElf
10-10-2015 09:40 PM
jaretstuff
08-04-2015 02:08 PM
PlayAwhile
07-20-2015 11:36 AM
Poncho0206
07-10-2015 06:21 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: 03 tacoma manual hub conversion
