02 sensor rip off....
Old 10-10-2005, 03:01 AM
grimpy's Avatar
I was thinking of getting a new 02 sensor since I think it is getting bad as I only get 15mpg... Anyways so I check prices and that POS is over $200 just for the precat one...
I need the CA emission pos one for my 00 4wd v6......
Anyone know where is the best place to get one pre cat CA 02 sensor?
URD has the denso one for like $215 shipped
Autozone list BOSCH OE for $262 plus tax or BOSCH universal for $105 plus tax...
I may lean towards the universal one. Anyone ever use a universal one??? How easy is it to wire up??? I know how to splice and connect wires... I thought my prev BMW having 4 oxygen sensors was a pita... Those were only $100 a pop for the OE ones...
Old 10-10-2005, 05:31 AM
MTL_4runner's Avatar
On 99+ vehicles the precat sensor is actually an A/F sensor (different P/N and more expensive) vs a standard O2 sensor so I would be very careful about getting a universal sensor (many have had problems after install with the universals). If it were my vehicle and I was sure it was the front sensor that needed replacement, then I would go OEM for sure.
Old 10-10-2005, 10:07 AM
AW1090's Avatar
check here... http://www.sparkplugs.com/results_app.asp
It's better than bosch and pretty good prices.....the universals are easy just cut the plug off, strip and butt the wires together. Instructions will come with the o2 sensor you pick up....If you're worried about getting the wrong part just call your toyota dealer and ask for the part number then compare it to the ones on the list.
Old 10-10-2005, 04:03 PM
grimpy's Avatar
thanks for the help guys... I contacted 1sttoyota and they ran a check on my vin and said it wasn't a CA emissioned vehicle so a new Denso 02 sensor will only cost $90... Wow, the CA emissioned vehicles gets screwed!
Old 10-12-2005, 07:50 AM
ebelen1's Avatar
Does this affect you passing smog in Cali?
Old 10-12-2005, 07:58 AM
Localmotion's Avatar
i think gadget sells o2s for cheap. www.gadgetonline.com
Old 10-12-2005, 09:26 AM
cootees's Avatar
I can see what kind of deal I can get them for you if you want me to. SR5 or luxury edition? a/t or m/t? Also my bosch catalog only lists a universal sensor 2wd '00 4runner.
Old 10-12-2005, 11:30 AM
grimpy's Avatar
I ended up getting it from URD-USA. I have no idea how if affects CA smog... I hope the car wasn't refitted with the CA O2 sensor when it came to Cali...
Old 10-13-2005, 06:11 AM
ebelen1's Avatar
That's what I was thinking. I don't know how you'd pass smog w/ an 02 sensor that is not California compliant. Oh well, someone told me that 01's and beyond don't even require smog; I don't believe him but that's what he told me.
Old 10-13-2005, 06:33 AM
X-AWDriver's Avatar
I found the CA version for $170 but I'd like to find it a bit cheaper when mine does go out.
Old 10-13-2005, 10:38 AM
grimpy's Avatar
On this thread some guy in NorCal had a Az Runner and it was going to be held Fed. emissioned come smog... W00t!
https://www.yotatech.com/forums/show...192#post716192
Old 10-13-2005, 06:35 PM
BOSTON4RUNNER's Avatar
dont get a universal one
i did and it still threw codes and i took alot of time splicing it in nice
bought a direct plug in, never had a problem again...
NorCalVP
or whatever his name is, he might have a used one and he is also in california,,
Old 10-13-2005, 09:06 PM
grimpy's Avatar
I already ordered one from URD. Just waiting for it to get here now. Denso 02 sensor.
jb451
7
10-07-2022 06:58 AM
EatChipsNow
09-09-2015 01:25 AM
Kreedy1
09-08-2015 06:33 PM
moparbay
09-03-2015 12:48 PM
tj884Rdlx
08-28-2015 12:04 PM
Quick Reply: 02 sensor rip off....
