02 4Runner Will Not start!!
ok so i know i made the mistake, and washed my engine compartment with the engine off, let dry out for a good day or so. when i went to start it i got a single click from the starter. took the time replacing starter contacts still just a single click. had the battery checked, its good and charged. still nothing, any suggestions?
moderator-move this to the noob section if needed
How did it look inside the starter when you took it apart? If it was really corroded, changing the contacts won't always do the trick. Did you clean the 2 connections feeding to the starter?
