01 4runner sr5 no reverse a340f
Old 06-01-2015, 11:22 PM
Jethro540i's Avatar
I recently bought a 2001 4x4 4Runner with no reverse. Does nothing when put into reverse. Shifts through all the gears perfectly in forward. It has code P1760 (Shift Solenoid Valve No. 4 Circuit Malfunction). What am I up against here? Closest junkyard trans is 2 hours away for $900. What am I looking at if I were to tear it down? Difficulty/parts needed/cost? I'm very mechanical. I just want to get it back on the road for now. Any info would be great. Thanks!
Old 06-02-2015, 12:10 AM
Jethro540i's Avatar
Update...I randomly got reverse to work and seemed fine then I couldn't get it again....
Old 06-02-2015, 03:59 AM
donomite49's Avatar
Tried import transmission IPT?
I'd call them if nobody chimes in here
Old 06-02-2015, 05:29 AM
94 Newbie's Avatar
Smile
It sounds like the earlier series 80 Land Cruisers that used shift solenoids in the pan - if so, you would have to remove the pan to access it.
That's a swag, though, as I am not a tranny expert.
Free bump, though.
Good Luck!
Britt
Old 06-02-2015, 07:22 AM
Jethro540i's Avatar
Thanks for the replies, guys! I have gotten reverse to kick in a few more times. Goes in like normal and moves fine then all of a sudden there's nothing at all. I also know next to nothing about transmissions but definitely would like to learn more. donomite49 I'll keep that in mind if I don't find anything! From what I've read there are 3 solenoids if I can figure out which one and get a part number for it. Or if they're all the same? Also found some ways to test them, once out of the transmission. Thanks again!
Old 06-02-2015, 10:29 AM
donomite49's Avatar
Try YouTube they have videos for everything
Old 06-02-2015, 12:18 PM
94 Newbie's Avatar
Lightbulb hard to do on a phone!
Www.bulkpart.com - I did not intend to, but downloaded an exploded view pdf.
Looks like there are 3 solenoids on the valve body , but if there are also pn's
I can't see them ...
Britt
Old 06-02-2015, 02:01 PM
millball's Avatar
Test range selector switch??
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 01 4runner sr5 no reverse a340f
