01 4runner alarm has locked ignition
Old 08-26-2012, 06:35 AM
holleys's Avatar
The natery was disconnectedband reconnected, I have no FOB and cannot figure out how to unlock the ignition. Best I can tell it has a dealer installed alarm with both the red button and toggle switch on the left. I have tried several sequences of on/off and locking the door. Any suggestions?
Old 08-26-2012, 08:04 AM
ThatGuy1295's Avatar
locked or wont do anything. Like it wont even turn? Cause I dont think an alarm can lock an ignition.
Old 08-26-2012, 08:07 AM
holleys's Avatar
Sorry, the ignition will turn. But the truck will not turn over. It is the alarm, I found an old thread here, but not sure how the reset the alarm.
Old 08-26-2012, 10:12 AM
Staff
DeathCougar's Avatar
Sounds like it may be an aftermarket alarm if you have a toggle switch. I don't know any factory alarms that use toggle switches?
Most alarms are merely a circuit interrupt set that cuts the black wire to the switch. If you cannot get a FOB for it, take your lower dash off and CAREFULLY remove all traces of alarm setup. Return the truck to stock, and you won't have that problem anymore.
MO transplant
04-23-2023 11:58 AM
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
msane99
07-11-2015 08:08 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: 01 4runner alarm has locked ignition
