Zimsplat's 1993 Pickup Build
Old 05-22-2015, 06:52 AM
  #41
bump530's Avatar
Looks good. I like that you took the time to do it right.
Old 06-30-2015, 06:31 AM
  #42
zimsplat's Avatar
Old 06-30-2015, 11:04 AM
  #43
84 yota dude's Avatar
Just read through this build, badass work man! Learned a lot about the engine work especially. Is it smog legal though? And what about MPGs?
Oh and why cut and rotate the knuckle balls?
Old 07-08-2015, 07:31 AM
  #44
zimsplat's Avatar
Yo man thanks! Smog legal now? No. Before with the stock ECU it might/should have been able to pass a BAR inspection. The only question here would have been the Y pipe that I made. from my research, because the stock truck had it exit on the pass side, it would have to stay this way to pass the BAR inspection. Anyway, now with mega squirt and the Subaru injectors, its definitely NOT smog legal. where I live in California, we only have to smog when you transfer ownership of vehicles. The MPG is heavily dependent on how I drive it and the tires. with the stock 3.4 and some 30" tires towing a jet ski on the freeway, I've seen 20mpg. With the 37's before the supercharger, I used to average 13 MPG around town. With the supercharger, 37's and 5.29s, I still get 13 if i drive normally. however, at the coos bay dunes, my foot never left the floor and I burned up a 16 gal tank in 69 miles. it gets way better smiles per gallon than miles per gallon.
by rotating the axle housing to fix the pinion angle, the front caster angle is changed from a positive (good alignment, good behavior) angle to a negative (terrible handling). rotating the knuckle balls backwards puts them back in a positive caster angle.
http://image.hotrod.com/f/9405720+w6...er_diagram.jpg
Caleb
Charecter1
11-06-2023 10:08 AM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
colinmil
07-06-2015 04:03 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Zimsplat's 1993 Pickup Build
