WHAHAHAJR 1992 22RE 4x4 build or should I say rebuild
Old 01-12-2012, 09:38 PM
  #81
RMP8080's Avatar
Good thing your not in one of these states that check those things. I did EGR bypass in my diesel vw it works great no carbon build up in the intake. Only by product is smoke lots of smoke.
Old 01-13-2012, 05:03 AM
  #82
WHAHAHAJR's Avatar
Wink
People pay to make thier diesels smoke around here anyways.
Old 01-13-2012, 05:05 AM
  #83
WHAHAHAJR's Avatar
I only drive my truck 50-100miles a week max.
Old 01-13-2012, 06:53 AM
  #84
RMP8080's Avatar
Yea, I do 89 miles one way to work so the diesel @ 47 mpg helps.
Old 01-14-2012, 10:16 AM
  #85
WHAHAHAJR's Avatar
Well the pcv hose was cracked. So put a new pcv valve with grommet and hose. Put a pcv with a 90 and used a straight hose. The old pcv was a PITA!
Old 01-14-2012, 10:44 PM
  #86
WHAHAHAJR's Avatar
Parts came in from LCE. PAIR and EGR are a thing of the past. Now I just need to figure out which lines to block off.
Old 01-15-2012, 12:04 AM
  #87
WHAHAHAJR's Avatar
Old 01-15-2012, 12:08 AM
  #88
WHAHAHAJR's Avatar
They shipped me 2 PAIR block off kits by accident.
Old 03-05-2012, 05:09 PM
  #89
WHAHAHAJR's Avatar
Got a new tool box. Been looking for awhile on CL. Got it with keys for $70.00. Decent deal I think for the area.
Forgot my tape measure when I bought it and just took the guys word it would fit.
The more I looked I thought it was to big?
The test fit...
After install. Next morning...
Old 03-05-2012, 05:19 PM
  #90
WHAHAHAJR's Avatar
I think its time to take the bolts off the lift or whole front end and lock tight everything...
This is what I had to deal with last Thursday night. The bolts grew legs and disappeared from the front diff drop bracket on the drivers side. When I put it in 4wd it snapped the LH CV shaft.
For everyone with lifts. I recommend re-torquing and putting lock tight on all your bolts. Easy to do befire it gets to this.
Old 03-05-2012, 05:33 PM
  #91
WHAHAHAJR's Avatar
Also removed the sway bar. I snapped one of the sway bar links. So just left it off. I have new links and bushings but of coarse put them in a spot where I would not forget where they are? Now just can't find them...
Old 03-05-2012, 08:57 PM
  #92
RMP8080's Avatar
Wow that hurts, SAS time.
Old 03-06-2012, 07:30 AM
  #93
WHAHAHAJR's Avatar
Yeah that would be nice but 2 bolts and a new cv shaft later... It's was fixed the same day.
Old 03-06-2012, 07:23 PM
  #94
WHAHAHAJR's Avatar
Also this weekend I had my muffler welded back up and made a new battery bracket. Then I put my washer reservoir back on. Which I now found out is not working. Need to check for power then check for any blockage.
Old 06-14-2012, 08:14 AM
  #95
WHAHAHAJR's Avatar
New tires. 315/75R16 Procomp Xtreme M/T mounted and balanced today. I going to set toe and check alignment this weekend.
Old 06-14-2012, 08:52 AM
  #96
JeremyW94's Avatar
Nice bud. Awesome truck.
Old 06-14-2012, 10:52 AM
  #97
WHAHAHAJR's Avatar
Thanks man. It rides so smooth and quiet now. The Nitto Mud Grapplers were super loud. Even the ride seems less harsh now.
Old 06-14-2012, 11:39 AM
  #98
JeremyW94's Avatar
Nice, I bet it does. I'm suppose to be going to pick up a 92 this Saturday, basically going to rebuild it as well. At the moment it has 35 12.50's on it, I will be going down to 33 12.50 as soon as possible as well though.
EDIT: I like the rims you got as well. Could you take a better full body picture of it? I'd like to see what it looks like as a whole.
Old 06-14-2012, 12:27 PM
  #99
WHAHAHAJR's Avatar
The truck or the rims. I have plenty of pic of the truck in my build and profile.
Old 06-16-2012, 04:24 PM
  #100
WHAHAHAJR's Avatar
Took these yesterday. The lighting makes it look like I cleaned it up but I did not.
The new meats
Quick Reply: WHAHAHAJR 1992 22RE 4x4 build or should I say rebuild
