UpTheYotaPunx's 1990 Pickup Build-Up Thread
Old 08-31-2009, 09:30 AM
UpTheYotaPunx's Avatar
Meant to start this when I first got the truck but its only a few weeks old. Payed $3000 for it with new clutch/brakes and a rebuilt motor/new head, 200,000 miles on body. Anyways heres how it started out...
Old 08-31-2009, 09:31 AM
AZkid's Avatar
looks like a good start
any plans for it?
Old 08-31-2009, 09:37 AM
yeah ive got some updates uploading more pictures now!
Thanks btw
Old 08-31-2009, 10:48 AM
cutoff the running boards and the spare out with a sawzall.
unbolted the valence..
i replaced the dim overhead light with an LED kit, i had to trim the fuse style tubing to fit but it works great, ill upload some night shots soon
pretty frozen ha
ground down the bolts with a grinder to get the mechanism down, after we had gutted it
Old 08-31-2009, 11:34 AM
drilled a hole for the threaded rod to replace the spare tire mechanism
put a lock nut with a 2" washer on top then a chunk of a pressure treated 2x4 with an aluminum bar.
cleaned up the spare
we utilized the two nuts as a lock washer to tighten the lock washer above the steel.
and a cable for overkill
Old 08-31-2009, 11:40 AM
I decided to make a V4 emblem for my truck, I started with the cheap plastic crap and quickly went to aluminum.
finished.
Old 08-31-2009, 11:49 AM
New wheels and tires! wheels are the Black Teflon coated ATX chamber's, tires are 31x10.5 R15 BFG All-Terrains.
butt sag
my mom backed into it the other night, no big deal though
Old 08-31-2009, 12:07 PM
Painted the windshield wiper arms and got new wipers...
now it has a new life
Old 08-31-2009, 10:04 PM
AZkid's Avatar
make me a v4!
Old 09-01-2009, 08:09 AM
ha glad you thought it was funny too
Old 09-01-2009, 09:19 AM
AZkid's Avatar
nah im serious i want one.
and your truck looks alot better with those rims and tires.
Old 09-01-2009, 09:56 AM
algranger's Avatar
V4? You know its an inline 4 right? Or is that the joke..?
Old 09-01-2009, 10:35 AM
AZkid's Avatar
pretty sure its a joke since everyones always like
"hey what do you got under the hood?"
"a v4!"
Old 09-01-2009, 11:01 AM
algranger's Avatar
Lol yeah, i figured, because i've heard someone say "oh yeah my Toyota only has the v-4... r22 motor"
Old 09-01-2009, 02:59 PM
Fossilized
Staff
dropzone's Avatar
Make it a real V-4...You might be able to find a 1967 Saab with a V-4 in a Junkyard somewhere like maybe Sweden:
http://www.saabnet.com/tsn/models/1967/pr1.html
have fun
Old 09-13-2009, 03:25 PM
yeah its just a joke, i know its not a V4 ha
Old 09-16-2009, 09:24 PM
Replaced Horn
So my horn had Laryngitis, which most of you probably have experienced already. Anyways I had this siren laying around from a buddy of mine. I drilled out the rivets on the factory horns male connection.
I used my knife to carve a small notch on the edge of the recess for the new wire from the siren. Stripped the wire coiled it in the recess, jammed a pop rivet washer in to hold the wire in place and finished it off with a pop rivet.
Now the siren plugs right into the original horns connection. The siren isn't so much cool as it is funny, but it's better than nothing for now ha. I also utilized the bracket from the original horn and secured the siren in the same spot behind the grill. It makes a pretty loud noise somewhat reminiscent of a police siren if you beep it twice. Anyways I'll probably replace the siren with a better horn but I thought this was a pretty cool/simple mod.
Old 09-16-2009, 09:29 PM
gTgarrett's Avatar
lookin great so far! I really like the tires
Old 09-27-2009, 09:34 AM
91_TOYOTA_4x4's Avatar
looks good dude! 4v lol
Old 09-27-2009, 10:44 AM
gTgarrett's Avatar
Looks great so far. that rust looks pretty nasty, hopefully you can get most of that replaced or fixed
Quick Reply: UpTheYotaPunx's 1990 Pickup Build-Up Thread
