thspittingllama's 1st gen 4runner build
just got my first run of parts in!!!!!!
My completed thirds came in today from Marlin Crawler. I decided to just have them build them for me, rather than fighting with. And surprising enuff it was only about $100 more than if I did it myself, plus I got a warranty! thats what I call a good deal!! they are built exactly as planned other than I had them put a zip locker in the rear instead of an arb. I also had them build me a v-6 rear housing instead of the 4cyl, Looks like it will be a more solid choice. I also went with the high output compressor. my exhaust should come today too. a little early in my build plan, but i put a hole in the other muffler..... whoops!
Exhaust Came TOO!!!
Straight from LC Engineering......... I bring to you a complete Stainless Steel, Ceramic coated, mandrel bent, bolt on, thick as sh@t, work of art called, my new exhaust system! It was only a $900 shipped to my door. But should be a bolt on 20HP, and believe me I need that. IM SO EXCITED TO PUT IT ON THE TRUCK!!! Build starts tonight; I’ll try to remember to take pic’s as I go.
#27
Unfortunately no. But I’m doing better with work now so it shouldn’t be another two years before the next batch of parts.
#28
HAHA good catch, with a cold air intake as well a very similar build of header advertises gains of almost 20ftlbs of torque and about 10HP. (Rock Ripper from trailgear.com) http://www.trail-gear.com/images/dyno-testing.jpg That’s where I was getting my guesstamite. Sorry for the confusion.
#29
exhaust goes in first
I only had a few hours after work to give to the project, so i decided to do the small job first. here are some pic's of last nights progress.
#31
here's a pic of my old system, im sure you can see why it was time to go. My beeramid after night 1 (a little weak i know) and my rear third taped up and ready for primer
#32
painted the rear diff on my lunch break today, washed the truck and took some picks for ya.
#34
May i ask: why a 4runner and not the truck? Dont get me wrong, runners are awsome but that truck is in such good shape. Plus, the truck, i think, would be more useful with the bed.
#35
The biggest reason I have been contemplating swapping everything to a runner one day is that (although still many years down the road) eventually my family will outgrow a two seater. But recently I have been having second thoughts about it. It’s still a toss up for me. Cuz let’s be honest who wants more than one scared and crying passenger at a time anyways! I really like both I guess we will just have to see what happens. but then again, by the time im done with this build i'll easily be 20k into it, thats $ i'll never get back out. So I want to have something I can keep till I die. But idk. Maybe for now I should just re-title the build to pickup, cuz a runner swap probably won’t happen for a while, If it ever does.
#36
Well i don't have many pic's from last nights progress, but the rear third is in! Everything seems to be working well. i did have to do a little grinding on the housing to get the v-6 carrier in, but that was expected. other than that it went smoothly. I decided to make the whole axle new so i also replaced the wheel bearings and seals as well. then filled it with lucus synthetic 75-90. Tonight's goal will be to get the front diff in, then Saturday will be mounting, wiring and plumbing the air compressor. That reminds me..... I NEED SOME HELP! Where am i going to mount this compressor? Where have you seen them mounted or mounted your self. some advice would be great. maybe some pics?
#38
front diff is in
it wasn't to bad actually. got my compressor all wired up as well and plumbed. but once i turned it on i heard a leak coming from the rear diff. and it doesn't seem to be engaging, poop on a stick!!!! i think i may have to tear it back out now. errr i spent too much money for this sh@t.
#39
rear diff
got the rear diff out and it was leaking around the seal housing. I took it off and the seals looked good and covered in oil. not sure why it wouldn’t seal. My only thought is that the lucus oil synthetic 75-90 wasn’t thick enough, so I wiped some bearing grease on the seals and put it back together. Did a bench test and it sealed right up, and engaged. So I put the third back in, and so far so good. Went wheeling this weekend with it and its still working great.
