thspittingllama's 1st gen 4runner build
Old 12-15-2010, 11:11 AM
thspittingllama's Avatar
ok guys, so i just decided that i was going to change my Yota build from an 87' pick up to a 87' 4runner. well any first gen 4runner with ifs. I have done up a rough draft of what i want it to look like and i would love your input as i put together my parts list. This may be a bit of a slow build but it will get done lol. So here's what my rough draft looks like. and yes it was done in paint.
Old 12-15-2010, 03:35 PM
Ok guys this is the parts shopping list that I have started. Please if you find something that fits my build direction and it’s not on the list please tell me about it, Or even if you see something that is on it at a better price.
Drive train, Differentials & axle…
1- Front 7.5” 4:88 gears $177.65 “marlin crawler” (done)
2- Rear 8.0” 4:88 gears $177.65 “marlin crawler” (done)
3- 7.5” setup kit $149.65 “marlin crawler” (done)
4- 8.0” setup kit $109.65 “marlin crawler” (done)
5- 7.5” Detroit true track $549.95 “Marlin Crawler” (done)
6- ARB standard compressor $225.00 “Marlin Crawler” (done)
7- ARB 8.0” locker $799.00 “marlin crawler” (done)
8- 8.0” rear axle kit $145.00 “Marlin Crawler” (done)
9- 7.5” front axle kit $? Haven’t found one yet. (done)
10- 8.0” chromoly rear axles $249.95 “marlin crawler”
11- 8.0” heavy duty pinion seal $14.95 “marlin crawler” (done)
Total for build= $2,598.45+ tax and shipping (done)
Armor….
1. Front Bumper with stinger $395.00 “marlin crawler”
2. Rear bumper $275.00 “Wabfab”
3. Rock sliders $209.00 “Marlin Crawler”
4. Rear diff armor $69.00 “marlin crawler”
5. Interior roll cage $395.00 “marlin crawler”
6. Custom outer caging $400.00 “local shop?”
7. Front end skid plate $279 “Bud built”
8. Additional skid plating $? “custom stuff I’m sure?”
Total for build= $2,022 +tax and shipping
Dual Cases…
1- Dual t/case crawler box $629 “marlin crawler”
2- Speedo extension cable $29.00 “marlin crawler”
3- T case triple stick. $250 “Davez or Radesigns?”
4- Flat belly duel cases cross member $299.00 “Bud built” or $219 “trailgear”
5- Heavy Duty Transfer case mount X2 $150.00 “Marlin crawler”
Total for build= $1,357
Suspension….
- Total Chaos Caddy Gen 2 kit $1919 “polyperformance”
- Fox 2.5” RR coilovers w/springs $1,219.98 “polyperformance”
- Weld in Shock hoops $270.75 “polyperformance”
- King kong Steering upgrade $650.00 “polyperformance”
- 1” lower uniball conversion $399.00 “polyperformance”
- Ifs Weld on Frame truss $39.90 “polyperformance”
- T-100 axels $140.00 “local parts store”
- Total chaos idler arm $341.50 “polyperformance”
- Total Chaos solid motor/trans mount $925.00 “Totalchaos”
- 4” Allpro rear suspention kit $699 “AllPro”
Total for build= $6633.13 +tax and shipping
Engine performance….
1. Stainless steel Header $389 “LC Engineering” (done)
2. Stainless steel full exhaust $399 “LC Engineering” (done)
3. Stainless straight through patch pipe, cat delete. “$65 (done)
4. Pro Stroker short block kit .80 over. $2250 “LC Engineering”
5. Stage 3 cylinder head w/cam $1599.99 “LC Engineering”
6. Supercharger kit low boost $3395.95 “LC Engineering”
7. Pro Clutch Kit $249.59 “LC engineering’
Total for build= $8348
Body acc ect.
1. Carr light bar. $101.86 “carparts”
2. KC Daylighters 6” six total $387.00 “4wheel parts”
Old 12-15-2010, 07:49 PM
twistedyota's Avatar
looks like you have a lot of work ahead of you
Old 12-16-2010, 08:42 AM
Outsane's Avatar
that's a list!
Old 12-16-2010, 08:52 AM
RBX
RBX's Avatar
Nice, and thanks for posting up the prices....s'scribed!
Old 12-16-2010, 12:55 PM
yeah its going to take a while to get it all done.. but at least i have direction right? I still have my pick up so i need to find a runner with a clean body for cheap. i'll probably look for one with a blown motor or something. I'll keep building on my pickup for now, everything can be swapped over later. Gears and lockers are first on the priority list!
Old 12-16-2010, 07:53 PM
good luck
Old 12-16-2010, 07:59 PM
Jaino240's Avatar
Sub'd!
Planning everything out like that makes things less of a headache. Nice
Old 12-16-2010, 08:05 PM
yes it does unless you have 3 engine worth of bolts then you dont have to worry as much haha
Old 12-16-2010, 08:49 PM
Fossilized
Staff
dropzone's Avatar
Originally Posted by thspittingllama
Heavy Duty Transfer case mount $85.00 “ Marlin crawler”
for Dual Cases you are gonna need two mounts so add one more your list
Old 12-17-2010, 08:30 AM
richf's Avatar
$7,000.00 in suspension is alot of money. I'm sure you could put a solid axle under it for half that price if not less. Any reason you want the IFS?
Old 12-17-2010, 08:56 AM
yotarob2005's Avatar
Whoa buddy, hold onto your credit cards! It's gonna be an expensive build!
Old 12-17-2010, 09:21 AM
thanks will do!
Old 12-17-2010, 09:23 AM
yeah more comfortable of a ride as a daily driver. and The ability to jump it! lol but at the same time still be a moab capable machine.
Old 12-17-2010, 09:29 AM
richf's Avatar
OK. I new there had to be a good reason to keep the IFS and drop that kind of money into it.
Old 12-17-2010, 09:51 AM
yotasavg's Avatar
Saweeeeet!!! can't wait to see this happen!
Old 12-17-2010, 01:53 PM
ok guys i was really board at work today so i decided to further develop my paint skills. so here ya go... my dream 4runner playin on some slick rock in the sand dunes!
Old 12-19-2010, 07:07 PM
haha like the pic. but one question is it crawling in 2wd i dont see a front driveline haha
Old 12-19-2010, 07:26 PM
Bojangles's Avatar
Haha he's got a point.
And you know your way around Microsoft Paint huh?
Old 12-19-2010, 07:35 PM
BigBluePile's Avatar
Wow. Now thats a build plan! At least you have a direction. Some of those parts are possible CL/YT finds. Save some $$.
Quick Reply: thspittingllama's 1st gen 4runner build
