Teuf's SAS thread 88 toyota PU 22r-e
Old 04-07-2013, 02:28 PM
  #81
StewsRunner's Avatar
Hey man what primer did you use?
Old 04-07-2013, 03:23 PM
  #82
Teuf's Avatar
Rust-oleum primer grey.
Old 04-08-2013, 09:12 AM
  #83
Redeth005's Avatar
Originally Posted by Teuf
Now????????? should I use (extreme pressure Moly-Graph) in the trunnion bearings? And the syn blend everwhere else....
Dude it's coming along so nicely Tuef.
I used ny Valvoline syn power grease throughout the knuckles bearings spindles brifields and trunnion. I'm sure your syn blend everywhere wouodnt be bad. Then again. I've only done this one time so your guess is as good as mine lol.
Old 04-08-2013, 10:45 AM
  #84
Gizler00's Avatar
Definitely coming along nicely!! Keep up the good work
Old 04-12-2013, 10:08 AM
  #85
Teuf's Avatar
I am changing out the rear diff starting now. Out with the stock gears, in go 5.29 / with my 33 inch tires.
Old 04-12-2013, 10:14 AM
  #86
Redeth005's Avatar
U doing the gear install yourself?
Old 04-12-2013, 10:20 AM
  #87
93Xtra-Cab's Avatar
It looked like he already had the diffs built, so it's just simply pulling the old out and putting the new in.
Old 04-12-2013, 10:45 AM
  #88
Gizler00's Avatar
Nice man 5.29's. that's hat I'm running with my 33's.
Looking good
Old 04-12-2013, 10:58 AM
  #89
Redeth005's Avatar
Thats what i thought it was a bit off cuz i remember seeing 2 diffs earlier lol. I get it now. i mustve misread. TUEF TAKE PIX! how can you deprive me of the simple pleasures of Truck porn! lol
Old 04-12-2013, 11:08 AM
  #90
vang_22re's Avatar
Aw man this is getting better and better. When your done with it lets trade trucks hahaha jk
Old 04-12-2013, 11:13 AM
  #91
Teuf's Avatar
Ok I have blocked my front wheels, engaged 4x4 and am waiting on a floor jack. Mine died.
When my help shows up we will jack her up and pull the axles. I drained the gear oil, both filler plug and drain plug are out. Diff bolts are loose and the drive shaft is ready to separate. Still waiting on help.
http://i561.photobucket.com/albums/s...ps5772726b.jpg
Old 04-12-2013, 11:15 AM
  #92
Teuf's Avatar
Old 04-12-2013, 11:19 AM
  #93
Teuf's Avatar
I don't dare do this myself. My plan is to apply permatex, install dif finger tight till sealer oozes a bit, wait an hour then torque down. Again wait about 24 hours THEN fill with gear oil... OH yea I did go and get some axle oil seals this morn.
Old 04-12-2013, 04:27 PM
  #94
Discombobulated's Avatar
Looking sweet dude makes me want to man-up and do it but I need my rebuild before anything
Can't wait to see it when it's done it's gonna be wonderful!!!!!
Old 04-12-2013, 06:18 PM
  #95
Teuf's Avatar
Ok my help with a floor-jack showed up, I was hoping he would have brought his crawler.Name:  IMG_1681_2_zpsaae06f53.jpg
Sweet simple 85.
Jacked up and wheels off.
Misc / brake lines, 4 bolts to release axle
So far so good
No problem, nothing frozen to prevent removal.
I bought seals this morning, wrong ones. so the seals stay in. they looked good.
The old diff was a bear to get off, all the stud bolts ok, the bottom one was frozen, a good 30 minutes later and she is free.
Free bird
all of the old gasket stuck to the old third, the axle surface was clean. I used Permatex ultra grey/ 82194, I did not skimp on the application.
As you can see.
OK so we put it on and finger tightened the fasteners so the goop oozed a bit. Then we waited about 1 hour then torqued her down.
Axles in no problem.
Wheels on.
Old 04-12-2013, 06:30 PM
  #96
Teuf's Avatar
Getting closer
http://i561.photobucket.com/albums/s...pse73418a6.jpg
Good a second friend shows up to help bleed the brakes, so I could take pictures.
Pedal pump hold, no fluid passing through bleed nipple.
So I removed both nipples and wire wheeled them clean. back in and brakes bled.
Done, she will rest overnight so the Permatex cures further.
I am itching to take her for a 20 min warm up cool down.
I could not have done it without Francis (white rig), and Evan ( red rig )
Old 04-12-2013, 06:33 PM
  #97
Teuf's Avatar
Evans rig
Old 04-12-2013, 06:37 PM
  #98
Teuf's Avatar
Francis's crawler
Old 04-13-2013, 06:28 PM
  #99
BigBluePile's Avatar
Sweet! Nicely done!
Old 04-13-2013, 06:41 PM
  #100
toyospearo's Avatar
nice man!!
Looks great. I just did a diff almost exactly the same as you did. I used black permatex instead of the grey. Those axle seals and the little rubber seal on the outside last a long time. I wouldn't worry about not changing those out. It is rare they go out.
Quick Reply: Teuf's SAS thread 88 toyota PU 22r-e
