Swim's 1994 4runner Build Up thread- the Alaskan Assult Vehicle (AAV)
Old 03-07-2011, 02:20 PM
  #81
thrice's Avatar
I like that you kept the 3.0 instead of just swaping in a different motor.
Old 03-07-2011, 03:49 PM
  #82
Swim's Avatar
Hmmm it's been a while since I updated.
-Erich_870 - Engine was built buy a guy in Maryland. I grew up with his brother, so I got the "good guy discount" He builds trophy truck engines, so he doesn't really have time to build 3vze's. Transmission was rebuilt by Hansen Transmission here in town.
-yotasavg- Thanks man, engine mods are fun, but they are sure time consuming.
-ChefYota4x4- Thanks!! I've been following your thread since I first started on this board. Awesome work! The squeal was fun to track down..... yeah, not. Pulled the belts... nope, not there. Thought it was the false water pump.... nope. Pulled it down to the timing belt thinking it was the big idler pulley, as it turns out it was actually the primary tensioner. It was annihilated. So, new belt and tensioner. Slapped it all back together, re-timed it, and she's running again!
Old 03-07-2011, 03:51 PM
  #83
Swim's Avatar
-Thrice- Thanks man, I love the 3vze. It's so quirky... it just keeps you on your toes. I like those kinds of things..... I guess that's why I fly old planes too....
Old 03-18-2011, 10:29 PM
  #84
Swim's Avatar
New bumper, better photo coming soon.
Hella lights are on order, waiting for the HID's
Old 03-19-2011, 07:14 PM
  #85
Lumpy's Avatar
Is there a winch mount under the license plate?
Where ya find that?
Looks good!!!
Old 03-19-2011, 09:10 PM
  #86
Swim's Avatar
Where ya find that?
Looks good!!!
Thanks Lumpy.
Negative, no winch mount. I didn't want one as I don't winch. I had it built by the same guys building my "other" truck.
Old 03-19-2011, 10:03 PM
  #87
nvtoyota's Avatar
Nice 4runner I like you're build I also liked the 3.0 I had in my 94 ext cab I had almost 500thousand on it when my ex wife took it in the divorce that was with no major things done to motor or transmission only regular maitnance like timing belts and oil changes and tune ups one set of fuel injectors but great build
Old 05-01-2011, 06:48 PM
  #88
Swim's Avatar
A few updated photos.
Dogs ready for a ride
In the new Dog Proofed trunk
Old 05-01-2011, 07:03 PM
  #89
irab88's Avatar
careful- without a "spoiler" above the window, exhaust fumes tend to get sucked into the open window
Old 05-03-2011, 10:07 AM
  #90
caseymac's Avatar
can the valves be adjusted on the 3vz-e 3.0 v6 motor
does anyone know about valve adjustments on a 94 toyota 4runner? i heard that they can NOT be adjusted? can they be? i am lackin power and this is what i think needs to be done. but i had a friend say that they cant be adjusted??? its a v6 3vz-e 3.o
Old 05-03-2011, 10:55 AM
  #91
Lumpy's Avatar
Yepper you sure can adjust them. You have to use shims to adjust them since the cam sits straight on top of the valves.
Old 05-04-2011, 09:41 AM
  #92
Swim's Avatar
As some of you know, my plan for this vehicle is not to rock crawl, but to get me out to do the things I'm addicted to. Mountain Biking, Climbing, Surfing, Triathlons, Scuba Diving, and Skiing. So far, it's done a pretty good job, but there are some things that are missing that would make my life easier. It should also be noted that this vehicle will no longer spend time in a cold environment, it leaves for sunny socal in July.
The first and foremost, onboard water, and a hot shower. To some this would seem unnecessary, to me, it's important. I often head from the crag to work, or from the surf to work. Most of the time smelling pretty badly. I'd love to be able to pull out a shower head, flip a switch, and rinse off before work.
So here is the goal. Establish a way to have at least 10 gallons of water on-board, without taking up any additional cabin space. Be able to fill the water container without opening the tailgate, but also without cutting into any exterior panel that is visible. Install a hot water shower that will operate without having to lift the hood. All access will be up front.
Old 05-04-2011, 09:59 AM
  #93
Swim's Avatar
-----This is for a Water tank for my shower, not for fuel-----
So here's what I'm thinking. I no longer have a spare tire underneath. I'm thinking to keep costs low, but to make an effective tank, what about using 2, 6gallon jerry cans. The space I'm working with is 24x34x8", I can't get too close to the exhaust on the driverside otherwise the tanks will burn.
So here's what I've come up with. (PLEASE excuse the horrible rendering... I'm not feelin it today)
So far the cans seem to fit pretty well under there in the test fit. This is NOT permanent.
Now, how do I fill them, and is 12 gallons gonna be enough?
Old 05-04-2011, 10:10 AM
  #94
Lumpy's Avatar
Well first off I don't think that would be a legal fuel tank setup.
Second with them being plastic and down there like that would be an easy puncture, depending on the box surrounding it.
Setting up the pickup tube/tubes would be difficult I would think as well as a gauge of sort.
12 gallons is a little less than what the normal holds (17 I think maybe 15, around that anyway)
Probably your best bet would be to get a proper fuel cell. Cut the floor in the back and do a half mount (half in, half out) and box it all in proper.
Old 05-04-2011, 10:13 AM
  #95
Swim's Avatar
This is for water. For a shower. No fuel
Old 05-04-2011, 10:25 AM
  #96
irab88's Avatar
as long as you don't keep the water running, i think 12 gallons is fine. how are you heating it? engine coolant heat exchanger, electric, exhaust shroud, separate fuel heater?
Old 05-04-2011, 10:30 AM
  #97
Lumpy's Avatar
Sometimes I just don't know about myself...Damit use blue so I don't get confused. Help me out a bit!!!
Now that were on the same page...
Cap the caps...drill and cap the sides which is now the top and bottom. 2 on top 1 on bottom. One of the top make a garden hose connection and silicone it in and the other top one make a small breather line. Tie the 2 top hoses together with a y connector. On the bottom do the same garden hose connection. tie the 2 bottom together so it will draw from both at the same time. Have the fill line go into one of the inner rear storage compartment with 10' of hose. Use the existing breathers on the jugs to tie the 2 together again to help keep them balanced.
That better?
Old 05-04-2011, 10:38 AM
  #98
Mike S.'s Avatar
I love what you have done to the truck! looks real good!
Old 05-04-2011, 12:16 PM
  #99
irab88's Avatar
just one thing about the water tanks, as with almost any tank: don't draw water from the low point, but rather slightly above. that way, any dirt that gets in won't enter the system
Old 05-04-2011, 12:24 PM
  #100
Lumpy's Avatar
Yes, but if it's on the bottom it'll come out then you have clean water yet again.
Quick Reply: Swim's 1994 4runner Build Up thread- the Alaskan Assult Vehicle (AAV)
