RMP8080 1987 Pickup Build-Up Thread
#27
Thanks.............
yes sir, going to remove about 4 inches, want to keep a little piece for the tailgaters.
Order a new rear upper shock mount from Low Range offroad last night, should be here in 3 or 4 days. As I get extra money it will go into the TOYota, piece by piece.
#28
Well I did say 4 inches off the frame, so it's 7 1/2 inches. Now going to cut it off as we re-welded the receiver piece back on.
and as you can see new tailgate (free $) no rust
#29
UPS found my house, Part arrived of course day after a go back to work, but it's here my new Toyota Rear Upper Shock Mount from Low Range off road (Utah)
weekend welding
weekend welding
#35
Update: got another (FREE) 4.3 Block w/ heads. took it apart and this one is in better shape, so I may use this block for the SWAP. Pictures soon...........
#38
New (FREE) 4.3 V6 come out of a boat, looks really chean inside and out.
Going to changes the rings and bearing....soon I hope!
#39
today I worked on the rear bumper, added a piece of diamond plate, I think it looks great. need to be trimmed and paint (black bed liner)
#40
oh, then I did a cut a way for removing the 22r and adding the 4.3. this makes it easy to pull the engine, trans and transfer case together.
