kelvin 1989 4runner build
Old 10-14-2012, 07:17 PM
kornhuskerwizard's Avatar
your on the right track. just needs some ups!
Old 10-30-2012, 05:38 AM
kelvinb's Avatar
purchased some bilstein 5100 series shocks, 5x11 125lb springs, detroit IFS front locker, and an aussie rear locker.
Old 10-31-2012, 08:22 AM
nice!! id do 1.5 ballljoint spacers in front and it should set pretty level and give you clearance for the larger wheels and tires.
Old 11-01-2012, 04:26 PM
kelvinb's Avatar
Well from the time the wheels came off to being put back on took less than An hour. Zuk mod and new shocks installed was extremely easy. I used 3in of sch10 carbon steel pipe welded to the bump stop side to keep the spring centered. Sitting at 33.5in in rear and 34 in the front from ground to fender. Both shocks were useless. Driver side broke off as you can see in the picture. Next up is lockers bj spacers and Chevy springs.
Attached Thumbnails kelvin 1989 4runner build-forumrunner_20121101_192400.png   kelvin 1989 4runner build-forumrunner_20121101_192419.png   kelvin 1989 4runner build-forumrunner_20121101_192428.png   kelvin 1989 4runner build-forumrunner_20121101_192438.png   kelvin 1989 4runner build-forumrunner_20121101_192449.png
Old 11-02-2012, 03:59 AM
  #25
now put your other wheels and tires on, hows it ride?? gotta be better than before
Old 11-02-2012, 04:25 AM
  #26
kelvinb's Avatar
rides really nice. my headlights need to be adjusted as well.
Old 11-03-2012, 08:58 AM
  #27
im gonna try some rear springs from 89mustang gt and see if theyll fit
Old 11-10-2012, 05:46 AM
  #28
kelvinb's Avatar
Mobile app is crashing when i try to upload a picture so I'll do it later. Anyway i found a sweet bumper for sale on craigslist yesterday and picked it up last night for 100 bucks. He's on here but didn't catch a username. Anyways I'm having trouble getting my old one off. The two bolts that hold the body to the frame spin freely but are rusted to the steel sleeve under the frame. I'm guessing that's my problem since the hammer isn't pushing them out. Bigger hammer??
Old 11-10-2012, 10:19 AM
  #29
red rain!!! get the torch!!
Old 11-10-2012, 02:25 PM
  #30
kelvinb's Avatar
Got them out with an air hammer. A lot simpler than a 5lb hammer.
Old 11-10-2012, 03:23 PM
  #31
huskers win!! wheres the bumper pic??
Old 11-16-2012, 10:02 AM
  #32
kelvinb's Avatar
Old 11-19-2012, 03:58 AM
  #33
nice! did u get it on yet??
Old 11-19-2012, 04:21 AM
  #34
kelvinb's Avatar
no. the holes do not line up, and it hits the fenders. i will need to make some shims at work to make it fit. it should be pretty easy.
Old 11-20-2012, 01:16 PM
  #35
gettin closer. looks lots better than the smittybuilt tube bumper
Old 11-25-2012, 11:13 AM
  #36
kelvinb's Avatar
i found some 2x2 square tubing and welded it to each side of the truck, drilled holes in it and used 4 5x8x1 bolts to bolt the bumper up. it is temporary as id like to put a flat piece of 3/16 across the entire front. beneath it will be another piece of 2x2 square tubing to mount the leafs when i get around to doing the solid front axle swap.
i found a deal on craigslist for an 85 yota front axle locked and high steer, along with a rear setup for a 4 link. i traded my corporate 14b and 300 dollars for them.
Old 11-25-2012, 06:54 PM
  #37
looks good.
Old 01-13-2013, 01:30 PM
  #38
kelvinb's Avatar
about a week ago i came across some ammo boxes so i bought a few. i think ill buy some more just because its endless what you can do with them. just now i finished my new center console.
used the original rear holes/screws and drilled into the body for the front 2 screws. very simple.
its about the same size as the original consoles outside dimensions but obviously more space inside. i will be cutting a small metal bracket with holes for the 3 switches.
Old 01-13-2013, 01:53 PM
  #39
wow can u make a bbq grill outta that n cook tbones on the road!!???
Old 01-13-2013, 04:21 PM
  #40
so wheres the chevy 63" rears
Quick Reply: kelvin 1989 4runner build
